Old 04-17-2013, 11:23 PM   #1
genecusano's Avatar
Angry Question Honda eu2000i
I have a 21FBRS Micro Lite. I have a 30 amp surge protector. I also have a Honda eu200i gen. When I plug the TT into the gen the surge protector tells me I have an open ground. Is there away I can run the TT safely with an open ground?
Gene & Betty
2011 Silverado
2013 Flagstaff Micro Lite 21 FBRS
Mission, TX
2013-100..2014-180..2015-175..0
genecusano is offline   Reply With Quote
Old 04-17-2013, 11:35 PM   #2
Have you grounded the generator? Gensets need a ground which is usually accomplished by driving a copper rod into the ground and hooking it to the generator. There is a connection for this on many gensets. Should not need a large rod. See if the manual for the genset requires a ground to the unit. Just a suggestion...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 04-17-2013, 11:49 PM   #3
genecusano's Avatar
Maybe the question I need to ask is. Do I really need a surge protector when running off a generator?
Gene & Betty
2011 Silverado
Mission, TX
Old 04-17-2013, 11:53 PM   #4
bikendan's Avatar
NO! not with a Honda 2000w.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-18-2013, 05:47 AM   #5
I brought up the question to Progressive when I first found the problem. They sent instructions to build a pigtail to remove the error - to be used only when running from the Honda generator. .pdf file attached.
File Type: pdf Special Generator Pigtail Instructions.pdf (132.6 KB, 108 views)
2007 Chevrolet Silverado 2500HD Duramax Diesel
2012 Cedar Creek 30RL
Full Timers Since October 2012
RenoRock is offline   Reply With Quote
Old 05-30-2013, 02:45 AM   #6
maverick_415's Avatar
I just bought the Honda 1000 watt generator and questioned if I need to use my surge protector with it. Are there any particular reasons why it's not needed? Any other opinions?
2013 Forest River Wildcat Maxx 26BHS
2011 Infinity QX56
maverick_415 is offline   Reply With Quote
Old 05-30-2013, 06:35 AM   #7
TURBS's Avatar
Surge Needed or not the work around this is taking a 15amp plug and bonding the neutral prong to the ground prong and plugging it into gennie.
Problem solved.
Turbs
Old 05-30-2013, 06:37 AM   #8
TURBS's Avatar
PI surge protector wont turn on power
