Old 07-06-2014, 04:57 PM   #1
Goose killer's Avatar
Quicke flush upgrade
Was sad to find out my new cherokee 304bh had all the bells and whistles we were looking for except a black tank flush. Although some argue they are not necessary I disagree. Especially on a TT where the bathroom is not accessible with the slides closed (giving you no access to induce any water into the tank to aid in the emptying). Also the water flush elbows are an option ,but my TT has a 90 out of the tank, about 2' of pipe and another 90 before meeting up with the grey and dumping out. I see no way hose pressure could make that run and do any good. Needless to say I think not including a tank flusher ( listed as +- $40 factory option) was a big mistake. I asked the dealer about installing one before we picked up the unit, while he was doing our slide toppers. Although they have been reasonable on everything so far he quoted me $350. I knew a quicke flush was only $30 at best and he said it would involve 3 hrs labor. Well I decided to install it myself. I wasn't exactly thrilled with the quicke flush kit. Especially the extension and hose connection so I plumbed it with pex and installed a city water flange in the aluminum skirting. Nice upgrade I think. Cost well under $75 and was incredibly easy. No where near 3 hrs. Click image for larger version
Name:	ImageUploadedByForest River Forums1404683695.291066.jpg
ID:	57315Click image for larger version
Name:	ImageUploadedByForest River Forums1404683719.398418.jpg
ID:	57316Click image for larger version
Name:	ImageUploadedByForest River Forums1404683791.163076.jpg
ID:	57317Click image for larger version
Name:	ImageUploadedByForest River Forums1404683811.654960.jpg
ID:	57318Click image for larger version
Name:	ImageUploadedByForest River Forums1404683833.812998.jpg
2015 Nights Camped 32
2014 Nights Camped 21
2013 Chevy Silverado 2500 HD Duramax
2014 Cherokee 304 BH
Goose killer is offline   Reply With Quote
Old 07-06-2014, 05:56 PM   #2
mlangdn's Avatar
Very nice work! I need to do something similar myself. Thanks for the pics.
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
mlangdn is offline   Reply With Quote
Old 07-09-2014, 09:36 PM   #3
Taybrynn's Avatar
My new wildcat had the black tank flush but to be honest it's horrible compared to the quickie flush. Maybe it's not working quite right but was something I was looking forward to and now I'm thinking its worthless.
2015 Wildcat 337FB
2006 GMC Sierra 3500 SLT DRW - Duramax
Taybrynn is offline   Reply With Quote
Old 07-10-2014, 10:04 AM   #4
I guess maybe I'm better off then. I know my work is solid and the quicke flush works like a champ. My in laws have a keystone sprinter that came with a black tank flush. Sounds like it swirls around in there when it's running. I looked at the tornado flush but figured more moving parts = more things that could break. Sometimes keep it simple.
Old 08-11-2014, 07:57 PM   #5
Where on the black tank would you install an aftermarket flush kit? Also, what parts of the quickie flush kit did you use vs which parts did you make from scratch?
Thanks!
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 08-13-2014, 11:02 PM   #6
nateboothman's Avatar
How did you install it?
nateboothman is offline   Reply With Quote
Old 08-13-2014, 11:14 PM   #7
Where is the (Back flow preventer) in this system? Youroo!!
Old 08-14-2014, 08:44 PM   #8
I installed the quicke flush in the side of the black tank, about 2-3 inches from the top and just about center left to right. This is as per the directions that it came with. The tank isn't that tall, more wide. This is shown in the first pic. The actual quicke flush is the only part I used. You can buy it with or without the kit. I bought the kit but it turned out to be junk. You can simply hook a hose to the quicke flush every time if you want. (You would have to crawl under trailer). There is a back flow preventer in the quicke flush itself. (The part inside the tank). I used shark bite fittings and pex to go from a hoes fitting down to pex and then pex to a city water flange I bought on amazon (15$). I drilled a hole in the skirting and put the flange on the same side as my other utility connections. The flange also has a back flow preventer. So it's back flow prevented at the tank connection and at the hose connection. Double fail safe. Totally independent. Works perfect.
Old 08-30-2014, 05:53 PM   #9
Mrs Evans's Avatar
Can you tell me specifically what size PEX and which Sharkbite fittings you used to put this together? I'm putting together a shopping list and I'm no plumber! I can't tell by looking at your pics what to buy
Thanks!
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 08-30-2014, 09:12 PM   #10
Here's some pics of the fittings and stuff. I used 1/2 " pex. Not sure how small of a roll they sell. I had some left over from another job. You will need at least enough to go from the center of the black tank to the skirt plus allow for bends and such. I would say 10' of 1/2" pex and you should be safe. I ordered the quickie flush and city water flange ahead and then took them both to Home Depot to make sure I got all the right stuff. That's what I would recommend. That way you can try all the fittings together before you get started. There's tons of them and it gets confusing with all the sizes and threads.
Here's a basic list
10' x1/2" pex.
2 shark bite 1/2 " pex to 3/4 NPT female
I used watts fittings to go from the NPT to GHT (garden hose) and from the NPT to the city flange
The shark bites are mostly for home plumbing and the RV city flange was different thread.
upgrade
