Old 08-22-2013, 11:45 PM   #1
Denver, CO
garbonz's Avatar
Quiet Generator
Get a load of this. If anyone is interested I will publish a list of materials and such.
Quiet Honda EU2000i - YouTube
2017 Fuse 23T
Old 08-23-2013, 01:17 AM   #2
bikendan's Avatar
what are you doing to keep the temp down.
most boxes like this, need an air intake fan to keep the gen from overheating.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-23-2013, 06:37 AM   #3
TURBS's Avatar
I'd be interested on how it doesn't overheat as well.
Turbs
Old 08-23-2013, 07:17 AM   #4
Paul & Sheri
pwb01's Avatar
Impressive but that's an expensive fix for a generator that's pretty quiet to begin with. I don't see how to get a 30amp plug to it and there isn't much room for it and the adaptor. For an extreme noise requirement it may be worth the cost and effort to manufacture and transport.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 08-23-2013, 08:02 AM   #5
If he wanted quiet, why isn't the box lined with a sound proofing material?
C.B.
cbvp is offline   Reply With Quote
Old 08-23-2013, 08:15 AM   #6
RPAspey's Avatar
looks like it is lined with something. There appears to be some cables thru the back too. He mentions something about mixing the exhaust and ventilation air near the exhaust box. I'd really like to know about the compartment temps too. I like it though!
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 08-23-2013, 08:30 AM   #7
DDC
DDC's Avatar
Air cooled engines generally need a good flow of air that is cooler than the exhaust, he shows a wooden box for the exiting exhaust but no air intake for both cooling and the carb, it wont take long to weaken the mixture if it is drawing already used oxygen. Maybe there is more to this that the video failed to show.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-23-2013, 08:51 AM   #8
Denver, CO
garbonz's Avatar
Yeah, These are good questions and there is MORE to it but it is not easy to show it all in a short video, which is intended to illustrate the reduction in noise.
1. The ventilation and combustion air intake is below the generator and is a 4 in round hole covered by a screen.
2. the generator portion of the box is completely encapsulated (as much as possible) in both a sound deadening material, and a composite sound barrier. The "exhaust box" is also deadened and sound insulated.
3. The aluminum truck box is about 10 degrees above ambient, the exhaust box runs at 160 deg F, on high power. The generator itself is about as cool as when it is running outside. The only thing I noticed is that you have to leave the cover open for about 20 minutes after you are done running, as the inside of the box does heat up if the generator stops running due to latent heat and no air flow.
4. There is 250 CFM (cubic feet per minute) flowing through the generator and out the exhaust, entirely due to the Honda's internal fan.
5. I have a locking 15 amp plug and an extended run hose at the rear of the box that allows a dedicated line to be run to the camper power inlet, and an external tank.
6. I have professional experience in both noise control and industrial ventilation, so I kinda know a bit about the subject.
7. The box also doubles as a security measure for the generator itself and the rest of the box is used for storage. The rack is the stock one with a 250 lb capacity that came with my VCross.
I know this is not for everyone, but I love doing mods and I like the idea of drycamping with a whisper quiet generator.
2017 Fuse 23T
Old 08-23-2013, 08:59 AM   #9
TURBS's Avatar
Albeit great mod !
If you say its so then its so !
Old 08-23-2013, 09:01 AM   #10
Triguy's Avatar
Seriously nice mod, Garbonz!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
generator
