Old 05-05-2015, 08:37 AM   #11
Failures!
These are all 5th wheelers,with larger frames than yours,and they FAILED,except the one with (Cable and Bolts Drilled Thru the Rear Wall)!! Youroo!!
ID:	76192   Click image for larger version
ID:	76193   Click image for larger version
Old 05-05-2015, 08:44 AM   #12
fmc
fmc's Avatar
[QUOTE=HONDAMAN174;854974]Was thinking of altering the rear bumper myself and having a pro welder make a custom bumper and rack. What's holding me back is where I store it as I can't afford an additional 2-3 ft added. For now I have been putting my wood totes in my unit in the bathroom from the back door.[/QU
fmc is offline   Reply With Quote
Old 05-05-2015, 11:18 AM   #13
Left Coast
I'm liking OC's post.......never hurs to have a spare, or two!
Old 05-05-2015, 11:52 AM   #14
Blog: RVroadtripper.com
hbillsmith's Avatar
I had a Dutchmen Kodiak 24' trailer and took it to a machine shop where a welder fabricated a receiver hitch that attached to the frame. While he was at it, he also added welds to strengthen the bumper. To that receiver hitch I carried a "GearDeck17" Youtube for GearDeck here. In it I put my Generator and grill. Worked great. Now I have a fifth wheel and plan to put it back there.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-05-2015, 11:54 AM   #15
TURBS's Avatar
Your Dutchman Kodiak was not an ultra light travel trailer with a fabricated I beam frame was it?
And neither is your 5th wheel.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-05-2015, 12:00 PM   #16
The Dutchman Kodiak is a ultralight weight trailer. It has real I beams not made of three pieces of metal welded together. (I was just shopping for one). But I still think it is a bad idea to but a rack off the rear bumper.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-05-2015, 12:06 PM   #17
hbillsmith's Avatar
It's a 2013 Kodiak 242RESL with an aluminum i-beam. The fifth wheel is a 2016 Wildcat 295rsx with a BAL frame. The Wildcat came with the factory provided fold-up storage deck at the back. That deck is attached to frame extensions and is rated at 300 pounds.
My GearDeck's cargo box is 25#, the receiver frame is 50# but for the fifth wheel I will just be attaching the cargo box to the factory foldup deck. My generator weighs 86# and my grill weighs 23#. Sometimes I put gas cans in there and an occasional folding chair or two. With 17 cubic feet of storage, I never get over a couple of hundred pounds.
Gear Deck 17 Tech Specs
Check out the youtube video above. Also, I can't stress enough how important a good welder and fabricator was for me. I never used the bumper but I probably could have after he got thru finishing what the factory should have done. By the way, this is an expensive solution GearDeck17 $1100 plus fabricate/weld $350.
Old 05-05-2015, 12:07 PM   #18
Our 2006 Kokiak was supposedly an ultra light also and did have a real I beam, but it was a light wt I beam.
Old 05-05-2015, 12:08 PM   #19
Scubanut's Avatar
Don't do it!!! My RV dealer brought me into the service bay to show me a standard trailer bumper that had a bike rack on it. The bumper was still attached but was twisted like a twister licorice. Unbelievable it never tore off.
2012 F150 FX 4x4 5.0
2012 Coachman Freedom Express 292BHDS
Scubanut is offline   Reply With Quote
Old 05-05-2015, 12:15 PM   #20
...The Wildcat came with the factory provided fold-up storage deck at the back. That deck is attached to frame extensions and is rated at 300 pounds...
What you have and the OP has is 2 entirely different trailers. Yours came from the factory with the rack, the OPs came with a warning sticker. Big difference.
generator
