Old 08-27-2014, 08:07 PM   #1
Alberta8311ss's Avatar
Rear bumper mod to keep end caps in place
We ended up just about loosing both end caps on the bumper multiple times. To help fix this I drilled a hole though the bumper and the plastic caps at both ends of the bumper.
Then I installed a 4" hitch pin. Problem solved.Click image for larger version
Name:	ImageUploadedByForest River Forums1409188011.969222.jpg
Alberta8311ss is offline   Reply With Quote
Old 08-27-2014, 08:14 PM   #2
Kaadk's Avatar
That's a nice heavy duty pin. When my brother did something similar he just used cheap tent pegs.
Old 08-27-2014, 08:28 PM   #3
vinmaker's Avatar
What a great idea. I like it!!!
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-27-2014, 08:46 PM   #4
WFD
skewers work too.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 08-28-2014, 02:58 AM   #5
Well you certainly didn't under spec the job. Btw, I just noticed a new product for this. It is a aluminum end cap that pivots up out of the way and closes back securely .
I think they wanted 20 dollars for it which was more than I was willing to spend. Someone saw the need and produced a great solution. Sorry I don't have a picture .
Having said that, your solution is very good too.
Murphie is offline   Reply With Quote
Old 08-28-2014, 04:57 AM   #6
DAISY BOYKIN's Avatar
My fix for lost -------------
My fix for lost end caps is bead chain attached to bumper with a pop rivet and a stainless screw in the end cap with chain eyes. I never leave a end cap behind!
Also using the end caps that you have to squeeze to remove.
Name:	end cap chain 001.JPG
ID:	61602   Click image for larger version
Name:	end cap chain 002.JPG
ID:	61603   Click image for larger version
Name:	end cap chain 003.JPG
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 08-28-2014, 10:58 AM   #7
Bumper end caps-----------
Bumper end caps as you can see are secured with a bead chain. I purchased the chain (heavy duty) and eyes on the INTERNET. When I crimped the eyes
to the chain, I then soldered the crimp closed for good measure.
Old 08-29-2014, 05:46 AM   #8
I like the idea and it'll definitely keep you from losing caps. My concern is that, driving down the road, are you prone to having a cap come off and losing bumper contents? That was my rationale for doing the drill and pin approach similar to the OP (but a bit lighter duty on the pin - simply bent a small hook onto the end of a 6 inch long 3/16" diameter piece of aluminum and drilled a hole through the bottom for a small security clip).
Happy camping!
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 09-01-2014, 07:22 AM   #9
ChibullsAN's Avatar
One self tapping screw in each cap through the bumper did the trick. Keeps my poles in the bumper while moving. Don't want to have the cap and contents fall out just to get to the campsite to find the only thing left are the end caps hanging on a chain.....
2018 Rockwood Signature Ultralight 8329SS
ChibullsAN is offline   Reply With Quote
Old 09-01-2014, 08:00 AM   #10
Hi,
I'm into simple and cheap. I just drilled a hole in the bumper and dropped a galvanized nail down through the top alone. Never have had it bump out, and never lost a cap.
FWIW.
Rich Phillips
richp is offline   Reply With Quote
modifications
