Old 05-25-2015, 10:30 AM   #1
Rear Camera install question
I am ready to install a Voyager rear camera, which requires that I tie the wiring into a rear running light. I am not sure how the running light lens comes off. There is some sealant around it . Do I just clean the sealant off of the lens, and will it just snap off? Thank-you for any help you can offer.
Michigan-traveler is offline   Reply With Quote
Old 05-25-2015, 04:14 PM   #2
Don't know if you will be able to tap into the wires from inside the fixture. I Just installed a license plate camera ($40 eBay) and had to tie into the rear running light with butt splices and heat shrink. Hope this helps.
2016 Salem Hemisphere 302FK Showstopper
2017 Silverado 2500HD Duramax, LTZ, crew cab, Z71, 20" tires, TST 507 tire pressure monitor
DiverDennis is offline   Reply With Quote
Old 05-25-2015, 04:18 PM   #3
Yes it should just pop off. You may need a butter knife or something similar .
Jerry. Vietnam vet.
Retired
jgahlhoff is online now   Reply With Quote
Old 07-18-2015, 09:43 AM   #4
Driver Dennis has the right idea, Tap into the wiring harness, use butt splice connectors and protect it with shrink tube, he did a very good job illustrating the install.
Yooper mom troll dad is offline   Reply With Quote
Old 07-18-2015, 10:56 AM   #5
Diverdennis, how does the monitor receive video signal from the camera? I just see two wires for power.
Brian
2015 RAM 1500 Outdoorsman 5.7
2016 Rockwood Mini Lite 2104S
itgoes211 is offline   Reply With Quote
Old 07-20-2015, 07:48 AM   #6
Just bought a rear view camera and looking at the running light the lens pops off with a small screwdriver. However, I don't think just removing the lens is going to provide access to the wires. The base is going to have to come off which means cutting the caulking. I assume there is a hole behind it and I'm hoping there is enough wire there to pull some out. If possible I'm going to use small waterproof scotch lock connectors then drill a hole in the bottom of the lens for the wires to exit.
Brewhedd is offline   Reply With Quote
Old 07-21-2015, 09:03 PM   #7
It transmits on a 2.4G wireless signal.
