I am ready to install a Voyager rear camera, which requires that I tie the wiring into a rear running light. I am not sure how the running light lens comes off. There is some sealant around it . Do I just clean the sealant off of the lens, and will it just snap off? Thank-you for any help you can offer.
Don't know if you will be able to tap into the wires from inside the fixture. I Just installed a license plate camera ($40 eBay) and had to tie into the rear running light with butt splices and heat shrink. Hope this helps.
Driver Dennis has the right idea, Tap into the wiring harness, use butt splice connectors and protect it with shrink tube, he did a very good job illustrating the install.
Just bought a rear view camera and looking at the running light the lens pops off with a small screwdriver. However, I don't think just removing the lens is going to provide access to the wires. The base is going to have to come off which means cutting the caulking. I assume there is a hole behind it and I'm hoping there is enough wire there to pull some out. If possible I'm going to use small waterproof scotch lock connectors then drill a hole in the bottom of the lens for the wires to exit.
