Old 06-27-2015, 10:00 PM   #21
Herk7769's Avatar
Originally Posted by rockfordroo View Post
Here's the receiver my dealer installed on my Roo. Used for 3 years. No problems. Two bikes and rack, about 120 lbs.
I wish you much more continued good luck. It seems very secure (and heavy).
Not all frames look as rugged as your does.
The ultralites are made of strap iron I beams not extrusions.
ID:	81365   Click image for larger version
ID:	81366   Click image for larger version
ID:	81367   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-27-2015, 11:11 PM   #22
CWSWine's Avatar
Removing my spare tire, spare tire bracket, grill and grill bracket using a luggage scale has a total weight of 133 lbs hanging off my bumper from the factory. Bike rack and bikes are 78 lbs which is a few pounds less than my 16" spare bumper mounted on steel rim with mounting bracket. The bike and rack weights 55 pounds less that what the come from the factory. That lot more then 50lbs that suppose to cause welds and wall to crack!!!
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-28-2015, 12:24 AM   #23
bikendan's Avatar
The physics of bikes being held out and away from the back of the trailer, are very different from where the tire and grill bracket are located.
The bouncing bikes cause a lever effect on the bumper's welds. They cause a pulling back and down from the weight.
Old 06-28-2015, 12:37 AM   #24
You need to remember that the frame on a Crusader is much different than an ultra lite the OP first mentioned. It's like saying a 1/4 ton truck can pull 14k because my 1 ton can.
rana is offline   Reply With Quote
bike, bike rack
