Old 06-25-2016, 01:06 PM   #1
rear rack bins
So, I finally made good use of the rear rack. Found two bins that fit perfectly side by side. attached to the frame of the rack with U-Bolts. Used PVC caps to cover the nuts on the inside so they wouldn't tear anything. Presto, kids scooters, rug, outdoor toys, backpacks etc., now out of the back of my truck. Moving the spare tire to underneath the TT with a BAL Hide-a-spare system soon.
ID:	112159   Click image for larger version
ID:	112160   Click image for larger version
ID:	112161   Click image for larger version
jaybird141 is offline   Reply With Quote
Old 06-25-2016, 04:34 PM   #2
JustB_Rad's Avatar
Please keep us updated as to where you mount with the BAL....I looked at it, but my gas line is run right down the middle of the TT
JustB_Rad is offline   Reply With Quote
Old 06-25-2016, 04:36 PM   #3
JustB_Rad's Avatar
Also....the containers look awesome, but do they block the brake lights?
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017) at least 23 Nights Planned in at least 6 trips!
Old 06-25-2016, 08:03 PM   #4
Brake lights are still visible. Just the angle of the picture. Will do on the BAL system. Mine is a Grey Wolf 26dbh, should be enough room.
Old 06-25-2016, 09:30 PM   #5
JustB_Rad's Avatar
So is mine...The propane line runs back to even with the stove....and behind the rear wheels, the tanks are there.
Old 07-26-2016, 08:16 PM   #6
BAL Hide-a-spare
So I decided on the BAL Hide-a-spare, specifically the MODEL 28218: 70 to 75 frame, I-Beam Underslung mount for trailers with enclosed underbelly. There is plenty of room from the tire to the lp gas line, with room to spare. Probably could have gotten away with the non enclosed belly one. But I am happy with it.
As you can see in the pictures, it is no lower than my grey/black tank drain pipe and it was a fairly simple install, just had to get bolts/lock nuts/self tapping screws from lowes.
ID:	115430   Click image for larger version
ID:	115431   Click image for larger version
ID:	115432   Click image for larger version
ID:	115434   Click image for larger version
TT: 2015 26DBH
TV: 2010 Chevrolet Avalanche LTZ w/ HD trailering pkg/Power Stop Brakes/ProCharger Supercharger/Magnaflow Exhaust
Old 07-28-2016, 07:26 AM   #7
JustB_Rad's Avatar
Hmmmm, I wonder if there is enough room between my midship jacks (which are just in front of the springs) and the stairs. How wide is it?
Old 07-28-2016, 07:50 AM   #8
14" wide.
TT: 2015 26DBH
Old 07-28-2016, 07:59 AM   #9
Life is great's Avatar
Mods look pretty good!
Are you going to drag the bracket where the spare tire used to be? In the pics it looks pretty close to the ground.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - ??
Life is great is offline   Reply With Quote
Old 07-28-2016, 08:08 AM   #10
JustB_Rad's Avatar
14" wide.
Thank You!
