Old 12-16-2012, 07:59 PM   #1
lonestar007's Avatar
Question Rear View Wireless Camera system for Trailer
Anyone use/install and can recommend Rear View Wireless Camera system for Trailer (30" Work & Play) ?
I've looked and good one are over $300-$500...
Home security camera systems little chipper, like UNIDENT (under $200), but not sure about them. Some of them need 5V or 6V supply and I don't want to make it complicated having special adapter or running X-tra wires.
lonestar007 is offline   Reply With Quote
Old 12-16-2012, 09:19 PM   #2
Don't Camp Enough
DSMURPHY's Avatar
I have been using the I-Ball Camera iBall Hitch Camera | The Best Wireless Trailer Hitch Camera for about a year now and like it very well.
Its affordable and easy to use.
I'll put the camera on my tailgate for hook up and I have placed it on my TT's rear bumper to help miss hitting stuff when I back up!
All wireless and I store it in the truck console.
Good Luck!
'2016 Rockwood 8288WSA
'2010 Tundra
DSMURPHY is offline   Reply With Quote
Old 12-16-2012, 09:28 PM   #3
Are you using two cameras with one monitor? or you move camera from tailgate to the back of your trailer? and if you do - are you using velcro to attache camera?
I just put new thread on that problem in different aspect:
Since I have pretty long W&P 30" trailer, I'm thinking to get & install front bumper tow hitch which would make parking trailer much, much easy!
But! The one available is rated for 500 lb tongue Weight.
My trailer tongue is at list twice as much... Would 500 lb be good for a short use, like parking trailer with slow speed and short distance?
What do you think?
Old 12-16-2012, 09:51 PM   #4
Don't Camp Enough
DSMURPHY's Avatar
One camera with one monitor.
The camera has an adjustable magnetic base. I generally use it for hookup. I mentioned the rear bumper setup to illustrate the distance the camera is capable of transmitting. My TT is 34'+
IMO If the receiver you are planning to install is a 'bolt on' type, you could be limited with tongue weight.
I don't know what your tow vehicle is and I am not an authority, but look into having one welded on. I think it could be less damaging to your TV and should increase the amount of tongue weight you can safely hold.
'2010 Tundra
Old 12-16-2012, 10:32 PM   #5
I will look into that camera, thanks!
I have a new 2013 Chevy 2500 2WD full bed, so there no problem towing TT the usual way. The front mount tow hitch is a bolt on with 3 bolts on each side https://www.curtmfg.com/masterlibrar..._31023_INS.pdf
But i don't think welding it to the truck is a good idea, can loose MF warranty...
Only may be modifying the hitch itself, like welding X-tra bracket to the tongue.
Old 12-17-2012, 05:54 AM   #6
Don't Camp Enough
DSMURPHY's Avatar
The hitch looks substantial, not what I envisioned.
It should work going low and slow.
Best wishes.
'2010 Tundra
Old 12-17-2012, 06:10 PM   #7
I have the same filling. Just want to check if anyone use that type of front end hitch.
Thank you for your feedback!
Old 12-17-2012, 06:49 PM   #8
coderider's Avatar
Good Luck!
Have added this to my amazon wish list just in case my Santa is watching
Reviews look pretty good on this and very reasonably priced.
coderider is offline   Reply With Quote
Old 12-17-2012, 07:03 PM   #9
BTW - found here another camera system with 7" monitor 7" Wireless Rear View Back Up System IR Reverse Camera | eBay
Old 12-27-2012, 01:02 PM   #10
Sabre_Ray's Avatar
A friend of mine installed a wireless setup on his camper bumper, primarily for keeping an eye on his tandem tow (golf cart on a trailer), and he says it works great. This on a trailer that is 30-32ft plus the distance from hitch/truck bumper to the cab, so ~40ft total. Good Luck with this !!!
Ray, Christi and the kids
2013 Sabre Silhouette 291 BHTS
Sabre_Ray is offline   Reply With Quote
