Old 05-30-2012, 09:39 AM   #41
Originally Posted by bob213 View Post
If you want a good fan for behind the fridge try one of these. High CFM (74) Low DB (14) small amp draw. You will have to make your own mounting bracket. I put a toggle switch inline so I can turn it off in cooler weather. I also have the computer fan on the coils on the inside of the refrig.
SilenX 120x120x25mm - 14dBA - 72CFM iXtrema Pro Fan (IXP-74-14) - FrozenCPU.com
For a wider choice (& lower price), you might check
out these guys:
D.C. Fans | AllElectronics.com
Bought from them for 20+ years; good folks....
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
dnaraG_1M is offline   Reply With Quote
Old 05-31-2012, 08:05 PM   #42
Freds342's Avatar
out these guys:
cheers,
johnd
Post Thief here!:
I just bought a handful of 18-VDC lighted switches from AllElectronics for fifty cents apiece! They work well on 12-VDC, plenty of light and fit right into the F/R panels, but are only 8-Amps.
Made in France! Who'd a thunk!
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 05-31-2012, 08:43 PM   #43
bob213's Avatar
out these guys:
D.C. Fans | AllElectronics.com =
They do sell some inexpensive fans! But you need a fan that moves some air (CFM) and doesn't sound like a diesel doing it (DBA). Look at the specs and you will see that you get what you pay for....
bob213 is offline   Reply With Quote
Old 05-31-2012, 09:22 PM   #44
Choice is good..............
cheers,
johnd
Old 06-09-2012, 11:32 AM   #45
Too old to be too smart
SpringerPop's Avatar
Since I already had the roof-top cover and pedestal off to replace them anyway, I mounted these fans from All Electronics down in my reefer's "chimney", right above the finned coils:
12VDC FOUR-FAN ASSEMBLY | AllElectronics.com (new item)
I mounted a rocker switch high inside the above-stove cabinet to turn them off on cooler days.
They keep the top shelf inside at 37 degrees on a 95-degree day here in SoCal, and they're pretty quiet, too!
I can provide mediocre photos if desired.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-09-2012, 02:28 PM   #46
Pop
Just what I plan to do when I get all those dern
windows sealed. Ya beat me to it!!
Gonna control them with a pair of D.P.D.T., center-off
switches so I can run one fan, two fans, three fans, or
four fans. Maybe can match the temperature/sound level
to ambient conditions.......ie Red hot Texas summer / cool
winter.....
[Maybe next year will make a speed controller using a
thermistor epoxied to the condenser coils to sense how
fast the fans need to run....If I get bored next winter...]
Very good work, hope you enjoy 'em.
cheers,
johnd
Old 06-09-2012, 03:26 PM   #47
bob213's Avatar
4 fans that produce 32 cfm? Running only one would give you 8cfm. I don't think it will be worth the effort to put in a switch to control the fans individually. The single fan I posted a link to puts out 72cfm and is QUIET...
Old 06-09-2012, 03:37 PM   #48
Well, I guess maybe that it is right for *YOU*.
But we are all adults here and make choices for
ourselves, not for others......
cheers,
johnd
Old 06-09-2012, 03:40 PM   #49
bob213's Avatar
OK... excuse me.
Old 06-09-2012, 03:49 PM   #50
OK... excuse me.
Excused.
We have both given links to fans that one can use.
Which a person chooses will depend on their needs.
Let's let 'em make their choices without trying to
impose our own choices. After all, we cannot know
the physical enviournment of their reefer "chimney".
And we sure as heck cannot know what their idea of
"quiet" might be. Some folks will have very acute
hearing and some darn near deaf. My idea of quiet
and your idea of quiet simple are not appropriate.
cheers,
johnd
edit:
PS As you suggested earlier, reading the specs
for the four fan assembly shows 48CFM, not 8 CFM
for *EACH* fan. A total of 192 CFM with all 4 running.
Not too shabby.....if that's what you need.
fan
