Old 11-14-2017, 03:26 PM   #1
removal of gas furnace
I have a FR Salem Cruise-Lite 214 QBXL that has only been used (and will only be used) in Florida. Since heating a small RV in Florida with an electric heater is not that much of a problem, I would like to remove the furnace and the box that encloses it and put in two comfortable modified recliners in its place. Has anyone ever removed a furnace like the model in my Cruise-Lite?? If so how much of a job is it and can it be done by a DIY'er?
Thanks,
Mo
moshe1436 is offline   Reply With Quote
Old 11-14-2017, 04:08 PM   #2
Chaplain Kent's Avatar
Sounds like a good project. Removing a furnace is relatively simple, I have done it several times. The worse was a pop-up infested with Chinese beetles and it stunk. While you are at it I would recommend taking out the propane line as well, that way it will never be a problem to you.
YouTube should be your guide.
Chummy V
2014 Forester 2501TS
Ford E-450
Chaplain Kent is offline   Reply With Quote
Old 11-14-2017, 06:11 PM   #3
Thanks! Sounds like something I can do and yes I would take out the propane line to the furnace!
Mo
furnace, gas
