Old 06-09-2015, 01:13 PM   #1
waiter21's Avatar
Remove screen door LATCH - Replace it with a magnetic catch
When we leave the exterior door open but want the screen door closed, getting into or out of the MH is very, very cumbersome.
you need to:
1) slide the latch cover open
2) release the latch
3) push the door open
4) slide to cover closed
5) then close the door.
URGH
I disabled the latch so it will not hold the screen door closed (It still works to hold the screen door against the exterior door.)
I installed a magnetic catch that holds the screen door closed.
Now when we want in or out, just push (or pull) on the door, and it pops open, no screwing around with the plastic cover or the latch.
NOT - I also installed a couple door handles so we don't have to use that cheesy plastic handle thing that breaks real easy.
I wrote it up and put it on my web site:
Modify Screen Door to a magnetic catch | 2001 Coachmen Mirada 300QB
ID:	79511   Click image for larger version
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-09-2015, 01:19 PM   #2
These work well:
New Screen Door Slide - Available for CC?
Although if you have the "main" door shut, why close the slider over the handle?
Iwritecode is offline   Reply With Quote
cat, door
