02-17-2013, 08:47 PM
Removing a Pullrite hitch.
Anyone ever think of modifying an engine hoist to use as a lift for a Pullrite 5th wheel hitch?
02-17-2013, 08:59 PM
Yes, I have a cheap engine hoist from Harbor Freight. I did not modify it but I do use it to take the Pullrite out.
02-17-2013, 09:41 PM
Denver, CO
Got mine from tool king, works great. Then lower the whole assembly onto a furniture dolly and roll it into a corner of my shed. 10-20 minutes tops.
2017 Fuse 23T
02-17-2013, 10:12 PM
I have a Curt 20K hitch and it is way to heavy for me to lift, even after taking the head off. To remove the hitch I take the head off, use a crow bar to pry up the base and drag it to the tailgate and then slide it off on the tool stand normally used for my miter saw. Been thinking about the engine hoist, just don't have much room in the garage to store it.
02-18-2013, 12:56 AM
Sirsea, I just checked Harbor Freight, and the one they sell folds, so it looks like it could work. So as long as I have a spot to put the hitch, the crane should be easy to store as well.
Second question. What do you use to hook it up? Chains? Slings? What are the contact points on the Pullrite? I know you shouldn't use the way tubes. They may be strong enough to take my rig, but if a couple of the mounting tubes bind up on the pins, it may be too late when you see the back end of your truck going up. Was thinking a couple of straps one in the front and one in the back under the Superglide.
02-18-2013, 01:08 AM
phat phrog stunt crew
bought an electric winch from harbor freight. mounted it to a 2x6x8L, laid flat across some rafters in the garage and lift mine out onto a piece of plywood with castors on it. 400lb lift capacity for under 100 bucks. in and out in less than 5 minutes. a back saver for sure. i use 2 straps, 2x8' long. works like a charm.
02-18-2013, 06:52 AM
I bought a deer hoist from Sportsman's Guide and use it to lift the hitch and generator out of the truck when I need a bare floor.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
02-18-2013, 06:55 AM
Commercial Member
I use the landing gear on the 5th to take it out of the truck.
Keep it attached to the king pin, pull the mount pins, and lift it right out.
I then have a home made cart I push under the hitch, drop the nose down until the hitch is on the cart, then wheel the cart into the corner of my garage until I need the hitch again.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
02-18-2013, 07:55 AM
The engine hoist has folding legs and stores in a small space. I use two ratchet straps shortened to about 36' and put the hooks in the slotted holes on the side of the Pullrite.
I have disassembled the hitch and taken it out of the truck but it is REALLY heavy and I don't want to get hurt or bend something. It is more like a controlled drop when it put it down.
I store it on a furniture dolly so I can move it around easily.
02-21-2013, 06:33 PM
I have a 1 ton hoist that I attach to the joist of my garage, I pick the hitch up, lock the hoist, pull out from under the hitch and then and set it down on furniture dolly. After the hitch is out I remove the rails from the bed and insert plastic caps to cover them. Works great.
Ford part# XL3Z-17D754-AA is a plastic caps that fits the pullrite bed holes nicely.
Me '70, DW'??, DS '98, DS '01, Ruby - the black lab
2014 Laredo 302BH/2013 Ford F350 SRW CC 4X4
Nights Camping 2014 - 13, Reservations to be kept - 16(so far)
2013 - 29, 2012 - 29, 2011 - 23, 2010 - 33, 2009 -35, 2008 - 29, 2007 - 31
02-21-2013, 06:45 PM
itch'n to road trip
I understand that Daisy Boykin (Sid) has some kind of contrapsion to remove his hitch...look him up and ask him.
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
02-22-2013, 10:21 AM
Denver, CO
What's a deer hoist?
2017 Fuse 23T
02-22-2013, 10:27 AM
Always Learning
I assume it's that thing hunters use to hang a deer so that they can gut & clean 'em. A quick Google search for "deer hoist" returns a bunch of results with pictures. (I had to go search to make sure it was what I was thinking of.)
02-22-2013, 10:30 AM
Garbonz, ask your local redneck. Basically, shot deer are heavy. You need something to help load and remove them from your truck.
02-22-2013, 10:49 AM
And skin it
02-22-2013, 12:01 PM
what if he doesnt have any redencks locally? i know they arent in short supply or high demand, but they just arent available on every corner
02-22-2013, 12:28 PM
Denver, CO
Heeheehee. I was kinda looking for product information. But I guess I can ask around here for somebody with a gun and a truck ( I assume you need both of these) to see if I can find out.
2017 Fuse 23T
02-22-2013, 12:52 PM
do you have a cabellas, bass pro or large sporting goods store in your area? being from denver, you will probably have to look through a lot of skiing equiptment first
02-22-2013, 03:38 PM
02-22-2013, 03:47 PM
Camper Less Camping
I've been looking at these at HF myself, wondered if anyone else used them for their hitches...I've seen them for just over $100?
2013 Sabre 32RCTS-6 (sold)
