01-31-2015, 03:10 PM
Replace foam in cushions
Need to replace our cushion foam in dinette and wondered for those who have done it, what type of foam did you get? High or medium density? There are a lot of choices!
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
02-01-2015, 09:10 AM
I replaced mine on prior trailer. Brought high density from JoAnns fabric store and used electric knife to cut to size. Cost was approx. $180- only the material from store. Night and day difference, and well worth it!
02-01-2015, 10:38 AM
Always Learning
I got foam from www.foambymail.com - I found it to be quite a bit cheaper than what I could buy locally. I had it cut to specific dimensions. I should have followed their measuring instructions as I'm now dealing my fabric splitting at the seams.
From my invoice, here's what I got:
"Mattress or Cushion, Lux Foam - High Quality WITH DACRON WRAP"
02-01-2015, 01:25 PM
Thanks guys!
Pam & Don
2011 Rockwood 2304s
02-02-2015, 09:44 AM
Ret E-9 Anchor-clanker
Thanks ependydad! thats a great link.
02-02-2015, 09:56 AM
Always Learning
You're welcome. I've bought from them twice and the customer service has been outstanding both times. The first time, I was overwhelmed with the different foam types and options; I just emailed them and someone called me back a bit later to talk through my needs, the weights of people, and wrote up an order with recommendations. The second time, I procrastinated and they rushed my order.
I'll gladly order from them again!
02-02-2015, 10:50 AM
Yea, I procrastinate normally because I've never done that repair/mod before. This year is the slider mod. The cushions are smashed down, the carpet needs replaced to match the hardwood "runner" flooring I put inn last year. And, that accidental pee spot the dogs hit now and then next to the couch that I did not find in time, and now can smell. Have you heard anyone replacing a section of the breakfast booth? I'll need to replace the end piece, where the drawer slides in. Or go with table and chairs.
02-02-2015, 02:04 PM
Medium density will work the best in most situations. The high density will feel really good initially (especially after the crap the manufacturer uses), but most will find it to be too stiff over the long run. My mom owned an upholstery shop for 30+ years and did many RV and commercial accounts and always recommended the medium density for RV's.
2007 Dodge RAM 2500 5.9L
2010 Wildcat 30-LOFT
02-02-2015, 02:23 PM
I wish the cushion in my dinette was denser. It seems to compact too much.
Sounds like a big job to try to replace it.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
02-02-2015, 03:38 PM
Always Learning
For me, I only replaced the cushion bottoms and left the backs alone. The bottoms were pretty easy.
02-02-2015, 03:48 PM
But I imagine one must have all the dimensions right. You mentioned a few seams that are stressed. That could be because the new foam is slightly larger than the old foam. I think the hard part is getting the foam thickness down to the thickness you need. How does one rip a sheet of foam?
2015 HW296
2013 Chevy Tahoe
02-02-2015, 03:52 PM
Always Learning
The Foam Factory's instructions have you take the old foam out and measure the fabric. Not me - I'm smarter than they is. I grabbed a tape measure and just measured from the outside. The new foam is too thick.
The company sells different thicknesses, so you don't have to cut a sheet down to size. You just tell them their dimensions.
02-02-2015, 04:53 PM
Yea we just want to replace the bottoms and think the high density will be good, we camp a lot and just prefer a firm seat, easier on my old back!
Pam & Don
2011 Rockwood 2304s
02-02-2015, 05:00 PM
Buy the foam local if you can, you will save a ton of money. The stuff it quite cheap if you have a local baker of the stuff. Look up "foam manufactures" in your area, they usually have an outlet for the local vendors who repair ulpolstered funiture. Most places will cut it to order.
02-26-2015, 08:28 AM
Dr
Robb
02-26-2015, 09:31 AM
Use an electric knife to cut and spray foam with silicone to stuff in.
