Old 01-12-2014, 04:27 PM   #1
Boots49's Avatar
Send a message via Skype™ to Boots49
Replacing black water sensors
Need some help! When I empty my black water tank, the gauge registers 2/3 full, so I have decided to replace the sensor & wiring all the way back to the gauge panel. I found the mod. to replace the sensors but I can not seem to find how the wires were run up to the sensor? Could use some help.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 01-12-2014, 04:36 PM   #2
Triguy's Avatar
This thread might help; especially the pictures in posts 5 and 6 from Herk...
tank level indicators
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-12-2014, 07:12 PM   #3
Blaster 84's Avatar
It looks like Herc made this Mod in June, 1911. I would like to see a comment from him as to how we'll they have functioned since then.
2013 F150 XLT, SuperCab, Ecoboost; Rockwood 8285WS
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Blaster 84 is offline   Reply With Quote
Old 01-12-2014, 07:25 PM   #4
I know Herk has been around a while, but don't think he was even a twinkle in his daddy's eye in June 1911, in fact his daddy probably wasn't even around.
Old 01-12-2014, 07:36 PM   #5
Blaster 84's Avatar
I guess my finger, or something slipped. I believe he made the Mod in 2011.
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Old 01-12-2014, 10:34 PM   #6
Triguy's Avatar
Blaster, feel free to throw out a PM to Herk to make sure he sees your followup question. He's good with this stuff and can give you an update.
Scott
2012 Shamrock 233S
Old 01-13-2014, 08:02 AM   #7
Dave_Monica's Avatar
If you follow the GEO method, you'll have less issues regardless which tank probes you have.
https://sites.google.com/site/cbruni/
Dave
Old 01-13-2014, 01:14 PM   #8
Blaster 84's Avatar
I was hoping Herk would chime in for us all to benefit from his experience. I have been using the GEO method for a year and it doesn't help in my case. But I bought the RV used and the sensors may have a build up of someone else's crud on them. I tried the ice cleaning method also and that didn't help clean them off.
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Old 01-13-2014, 05:30 PM   #9
Herk7769's Avatar
Sorry, working on a shooting bench all day.
The Horst probes work great and are highly recommended by me. If you do the gray water tank, save yourself some heartache later and use black tank probes in both holding tanks.
The wiring is very simple. See attached diagram.
2/3 full usually means your tank walls are dirty and there is nothing wrong with your wiring. See troubleshooting guide.
Herk
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 117 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 122 views)
Lou and Laura - Shopping for a Camping Buddy
2008 GMC Sierra 30000HD Crewcab SB Allison Duramax
HAM CALLSIGN - KC3FFW
Old 01-13-2014, 05:36 PM   #10
Herk7769's Avatar
You need to try the RV-Digest-It (from Unique) cleaning.
Unique RV Digest-It Unique Distributing
While the procedure is here (numerous times-search RV Digest it here), this is it in a nutshell.
For CLOGGED tanks - whole bottle (1 QT) - fill with water and sit for a week; drain and turbo flush with system or wand. Repeat until free running.
For SENSOR errors, - 1/2 bottle - fill with water, sit 72 hours, driain and truboflush. - repeat if necessary.
Sensor errors are caused by slime on tank walls.
Watch video here: Horst Mircacle Probes - Get accurate reading on your RV's holding tanks
black, black water, water
