Old 12-17-2015, 08:28 PM   #1
Kenny kustom's Avatar
Res fridge sizing
Question.
My rig is in the city, at the dealer and I found a res fridge for sale locally. I cannot measure, but how does on get the fridge in the rv.
Through the front door?
How wide is the front door?
Window?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-17-2015, 09:05 PM   #2
Oklahoma Proud
MillerTime's Avatar
Probably need to pull the main slide out.
I don't see a point to switching unless your other refer goes out.
If your wanting to run more on solar power what benefit would you gain? And if only keeping the camper a short time, why would you want a residential refer?
Old 12-17-2015, 09:24 PM   #3
Long story. The DW started reading some stories about propane fridges catching fire....
So. Here I am.
2016 Sabre 36QBOK
I am nice!
Old 12-17-2015, 09:25 PM   #4
Also. I'm not a fan of that temp probe slider pos.
My $20k crossroads had a better fridge. Actual buttons on the top for temp.
2016 Sabre 36QBOK
I am nice!
Old 12-17-2015, 09:29 PM   #5
My solar and magnum hybrid project has more to do with the campgrounds we stay at.
No 50A at any of them.
I have dual ac, dual fridges, dual microwave. Etc.
The hybrid part will help with the 30A only part.
The solar is only for the late seasons when the cg turns off power and water, but camping is free.
That, and I'm a little off the wall.
2016 Sabre 36QBOK
I am nice!
Old 12-17-2015, 09:32 PM   #6
Oklahoma Proud
MillerTime's Avatar
So. Here I am.
2016 Sabre 36QBOK
I am nice!
Hmmm. Never heard of any actual cases of this.....lots of speculation. Id worry more about something in your vehicle failing and causing an injury. Like takana air bags or Chrysler airbag sensors etc.
Old 12-17-2015, 09:34 PM   #7
I never bothered to look it up.
But, it would be nice to have a larger fridge.
2016 Sabre 36QBOK
I am nice!
Old 12-17-2015, 09:44 PM   #8
Oklahoma Proud
MillerTime's Avatar
2016 Sabre 36QBOK
I am nice!
I know what features a 36 has....I've had one for the past 2 seasons and spent 27 weekends or extended weekends in it this year! Getting rid of the propane refer system will just add more to your 120v electric dependency. And late season wouldnt require ac and doubt you would be able run micros without 120 either.
I couldn't care less. Just sounds like a lot of trouble for little to no gain.
And a complete kitchen remodel would have to be done to accommodate.
Old 12-17-2015, 09:54 PM   #9
racer4's Avatar
I have seen entry doors that were 30", others were 32". I only measured a few.
Check the specs on the res. ref. for the size with the doors and hinges removed.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS, Disc Brakes
racer4 is offline   Reply With Quote
Old 12-17-2015, 10:17 PM   #10
Yea. It might be more work than it's worth.
I'll give it the summer, then decide.
2016 Sabre 36QBOK
I am nice!
fridge
