Old 12-01-2014, 09:18 PM   #11
Is that just a regular decora rocker switch? I didn't know those worked on 12v. How did you wire it?
Any switch that can handle 120VAC can easily handle 12VDC.
2011 Traverse LT, 3.6L, FWD
Old 12-17-2014, 04:11 PM   #12
Swift2
Swift 2's Avatar
Realy a nice job. It adds a lot of class.
Swift 2 is offline   Reply With Quote
Old 12-17-2014, 04:27 PM   #13
MagnoliaTom's Avatar
Here's mine. Thank you modguy
Name:	ImageUploadedByForest River Forums1418855191.253475.jpg
Name:	ImageUploadedByForest River Forums1418855205.518630.jpg
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is offline   Reply With Quote
Old 12-17-2014, 06:06 PM   #14
Dazed & Confused
M&K Hoffman's Avatar
I would guess that switch is marked "AC only". A commonly applied "rule of thumb" is that switch contacts, relay contacts, contactor contacts and small circuit breaker contacts, which are marked "AC only" can in fact be used on DC but only at about 10% of the rated voltage. So yes, I would say that switch will function fine. DC switches use a snap contact that breaks faster as DC is much harder to break than AC. AC voltage potential hits zero 120 times per second. DC goes to peak and stays there.
It should also be recognized that this is only a "rule of thumb" and that such use may well violate the NEC or other codes and regulations.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 12-18-2014, 11:34 AM   #15
+1
To put that another way - as you open the switch the current arcs across the contacts, and since AC essentially turns off 120 times per second it is very easy to design a cheap switch that breaks that arc since the electricity itself is helping. Since DC stays on constantly, the switch must be much more robust to break that arc, and at high amperage you could end up with an AC switch that is fully open/off but there is still an arc inside (and whatever you are powering is still on).
That arc will quickly set the switch on fire... then your camper.
In this case that switch is only powering a few lights so it should be ok. If you tried to use it as a master disconnect and all lights were on - maybe 30-35 amps total, you would end up with a meltdown.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 06-25-2015, 08:26 AM   #16
MOD Guy's Avatar
Originally Posted by techntrek View Post
+1
That's good info to know. Thank you, I would not have thought of that. This switch only runs one fixture with two bulbs. I will do some observing to see if there is a heat issue with the switch.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
light
