Old 04-14-2011, 12:56 AM   #11
Shasta1's Avatar
This post is in reference to an 1141 bulb.
At 5 ohms I'm measuring 6.8volts.....approximately 1/2 the voltage, and approximately 1/2 the brightness. I'll use a 7 or 8 ohm resistor for the 3/4 brightness position.
Heat is a concern. After several minutes under power, I have no difficulty holding the resistor in my hand, the bulb is noticeably hotter.
I'll double check the entire assembly at length for heat before I enclose it in the fixture.
Didn't mean to give the impression that this will work with an LED. Eventually I'll find a small array of LED's that will give me the half brightness I'm looking for. When I learn more about LED's, I'll probably build my own boards, which will also greatly reduce the energy draw, as opposed to the incandescent bulb/resistor.
Shasta1 is offline   Reply With Quote
Old 04-14-2011, 02:15 AM   #12
What about painting the inside of the lens white? I am thinking of doing this to the light over the head of my bed.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 04-14-2011, 11:12 AM   #13
Anacortesians
The "dimmer knob in your house" is actually a thyristor which only works on AC. It wouldn't work on 12VDC.
Frank and Eileen
No longer RVers or FR owners
Old 04-14-2011, 11:57 AM   #14
DAISY BOYKIN's Avatar
Hot resistor !!!!!!
Windrider is 100% correct about the resistor getting hot. Better make sure the resistor is not touching anything that is combustible . Why not just use a lower wattage bulb?
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-14-2011, 04:37 PM   #15
Shasta1's Avatar
Well, the answer to my situation was found at Walmart....
"ritelite" wireless led puck. 2 brightness settings, auto-on for use in cabinets or closets, and selectable direction of light.
Who'd thunk????
$6.97
Don't particularly care for battery operated (3 AAA), but this just might do what I need in both tv and bedroom locations.
Old 04-14-2011, 05:48 PM   #16
ohcnda's Avatar
Originally Posted by Shasta1 View Post
Is there a resistor that can be used to cut 12v in half?
I'm wanting to dim a couple of bulbs to half brightness.... is there a simple and inexpensive solution to this? The bulb is the 1141 size base.
use a lo93 bulb instead, it is 9.3 watts, much dimmer
F150 Crewcab XLT
2011 Flagstaff 831RKSS
OHCNDA
ohcnda is offline   Reply With Quote
Old 04-15-2011, 11:39 AM   #17
Shasta1's Avatar
Thanks ohcnda!
Excellent suggestion. Where do I find these?
I did a search and it seems that this bulb is used in landscaping lighting and pools. I'll check the Home Depot, Lowes, and Ace type stores.
Thanks!
Old 04-15-2011, 07:47 PM   #18
kalik282's Avatar
Here's a chart showing most DC incandescent bulbs and their voltage/wattage (CP)...
Bright Future International Ltd-Auto bulbs, Halogen bulbs, Incandescent bulbs, Miniature bulbs, Indicator bulbs, Night bulbs, Neon bulbs, Telephone bulbs LED bulbs.
Enjoy.
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 04-18-2011, 12:22 PM   #19
Shasta1's Avatar
That lo 93 bulb is rather elusive.....haven't found one yet.
Old 04-22-2011, 12:31 PM   #20
I found some lower wattage bulbs at automotive store, drastically reduced the amount of heat and still has plenty of light, original bulbs deformed the lens when child placed blanket over fixture in bunk. very happy with the lower wattage bulbs.
2008 Sequoia
2008 Shamrock 25RS
fbroussard is offline   Reply With Quote
12 Volt
