04-13-2011, 01:52 PM
Resistor for cutting 12v in half
Is there a resistor that can be used to cut 12v in half?
I'm wanting to dim a couple of bulbs to half brightness.... is there a simple and inexpensive solution to this? The bulb is the 1141 size base.
04-13-2011, 02:17 PM
Do a search for a 12v dimmable switch in google . Lots of options.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
04-13-2011, 03:08 PM
Yes, did that before I posted the original question.
I don't find $30+ inexpensive for the ability to dim a bulb.
04-13-2011, 03:13 PM
i would check Radio Shack they should be able to guide you in the right direction. Can't you just put a variable resistor in line like a dimmer knob in your house? they are cheap!
Dan, Kelly and Maddy.
Cupid and Kandi the Camp Dogs
Tomball, Texas
2006 Salem LE 29BHSS
2003 Ford Expedition Eddie Baur 5.4 w/ factory tow package
04-13-2011, 03:15 PM
04-13-2011, 03:18 PM
Originally Posted by scubieman
that is what I was talking about, something along those lines.
Tomball, Texas
04-13-2011, 03:25 PM
My previous searches turned up that box on ebay for around $3-4. Certainly an option, but a little bulky and exposed wires.
I'm looking to dim a living room light that we like to have on when watching tv. It's just too bright and distracting. I didn't know if lower wattage bulbs were available, or if adding a resistor (value??) would work. I'm looking for about half the light output.
04-13-2011, 08:31 PM
A 1141 bulb appears to be a 18.5 watt bulb. You could put a resistor in series to cut the light out put but it would have to be at least a 10 ohm 10 watt resistor and you will need one for each bulb you want to dim. And you won't be able to dim them. If you want the light output decreased without the ability to dim I would call a place like Easternlightbulbs.com (I have nothing to do with them). They should be able to tell you what bulb you could use to replace your current ones.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
04-13-2011, 10:56 PM
Thanks kz08h5!
That's what I was looking for.
Actually, what I found out today is that a 5 ohm to 6 ohm, 10watt should approximately reduce the brightness by 1/2.
I'm going to assemble a small rotary switch and use three taps; full, 1/2, and 3/4 brightness. I think I found one that will mount right in the fixture.
I'm planning on using this on two light fixtures; one in the tv area, and one over the headboard of the bed. My fixtures are the typical 2 bulb/two position switch, so the second position on the fixture will always be full glitter.
I've happily replaced the first position bulbs with the 32 led boards in all the other fixtures in my rig, and very pleased with the results! I found that info in this thread: LED 12 volt lighting: Long term results
Thanks for the link to Eastern light bulbs. Eventually I'm going to get up to speed on LED's and make my 1/2 & 3/4 brightness bulbs using them.
Thanks again to all for your replies. This is a great forum.
04-14-2011, 12:00 AM
Moderator
You can't reduce the brightness on LED bulbs by using a resistor. Also, those 10 watt resistors you have found will put out a lot of heat, so make sure you allow for that if you put them in the existing fixtures. Also at 5 ohms, you will only be putting about 4 volts to the bulb, probably won't even come on. I would look at a 2 ohm resistor, or make a reflector, or switch it for an led bulb with less lumen s.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 540 |
| 89 members and 451 guests |
| 02 rockwood, 4bnabird, 4Jeeperz, 4runner freak, 8261ss, abjb, backpacker3, Barney1, Barnman1, Bearcat55, bfisher82, bob7794, bouldercamper, brania, buzzmonster, campfun, CampinQueen, carsonizik3, ClampNfish, cmptrkd, cousin01, Cowracer, cstover, dashonthedash, daw592, depo, djorgensen3, dlmurray51, DonCath25ds, DonG, donh, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, Joseph5410, kalik282, kgmat, KKapa, Lonewolfcry, Mad4sax, mcdiver, Mike G, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, onetonford, Pa-cj5, Pinesman, Poppy Bill, PrairieBoy, prof_fate, punkaccountant, RattVader, rbrandon, RichN, Riva, Roamin Ovum, rschroe, Rugged Brown, Russ, ryoucrazey, seatosea, ses, Sparkbark, SpringerPop, tfennell81, Tom993, tonybab, transamz9, troyt, UPGRADER, VTX Al, wbdvt, Wbowman, Whiskeyjack, Whiteknight, whj77372 |
| Most users ever online was 1,025, Today at 01:04 PM. |
