Old 11-13-2008, 02:05 PM   #1
powerboatr's Avatar
Reverse Osmosis water filtration
After many months of water issues, and the fact the meds we take seem to lower our abiltiy to fight off clean water borne stomach issues
i installed a R/O system for all of our drinking water
took me a week, got hurt and had to let it stand
but this morning got it all hooked up. toughest part was running a new water line up under the flooring to the sink, WOW good thing i had a snake and just took my time
other than the kit, i purchased a 15' piece of clear polyethelen tubing water safe to add to teh r/o supply line
and one 3/8 connector for the line
i installed the entire system in the basement behind the partion that seperated the water pump and water heater, i had to re-locate the pump to the small wall, which worked out better for accessing the winterizing line, i ran the drain or waste line out th ebottom of the rig vice into the drain like the instructions said, so i wouldnt fill up my galley tank in short order,
i ran a small line fwd from teh pint of exit to make a drain off and added a roll up piece of pvc tubing to use if we are parked in an area i need to drain the waste water away from the rig.
doing the sanitation phase now and shoudl have 99% pure water in about 3 hrs now.
Name:	ro project1.jpg
ID:	1178   Click image for larger version
Name:	ro project5.jpg
ID:	1179   Click image for larger version
Name:	ro project3.jpg
ID:	1180   Click image for larger version
Name:	ro project6.jpg
ID:	1181   Click image for larger version
Name:	ro project7.jpg
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 11-13-2008, 02:07 PM   #2
powerboatr's Avatar
a few more photos
Name:	ro project8.jpg
ID:	1183   Click image for larger version
Name:	ro project4.jpg
Old 11-13-2008, 02:49 PM   #3
I've had an RO system in the house for a couple of years and I love it.
Nice job!
aintgotnun is offline   Reply With Quote
Old 11-13-2008, 03:05 PM   #4
powerboatr's Avatar
Greg
we had one in our houses in florida, sure makes a difference in coffee
one other thing to note
i lost ZERO basemnet storage space, everything went behind the partion wall
and only gianed 1.5 gallons of water weight and 6 lbs for the unit.
