Old 06-24-2014, 09:25 PM   #1
RG 6 cable question
I have a 2015 Crusader 351REQ and have a question about how the RG 6 is wired. I have 2 cable connections in my access panel one for cable and one for satellite. Does anyone know how I can find a diagram of how its wired? I removed the panel and see on cable is orange and one is black. The black one is for satellite but when I look at the connections at my living room tv the orange one is not connected to anything and the black cable is connected to my TV with only connected to the antenna at this time witch should not be that way if its for satellite.
The reason I'm asking this question is because I'm trying to hook up a Directv swm system so I can use two receivers and cannot have any splitters inline.
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
cajun225 is offline   Reply With Quote
Old 06-24-2014, 10:51 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Can you provide pictures of the access panel? Do you have a cable & Sat connections on the outside of the RV? Does the back of your access panel look like this?
donanddona is offline   Reply With Quote
Old 06-25-2014, 03:54 PM   #3
The is what the tv in my living room is connected to. The black cable marked satellite on the outside of my camper is connected to that.
Old 06-25-2014, 04:38 PM   #4
VinceU's Avatar
Dunno without seeing it, sounds like a Decal mistake, I always thought the sat wiring is orange?
Old 06-25-2014, 04:43 PM   #5
donanddona's Avatar
I believe you will have to use a decoder prior to entry to the RV. Control of the decoder is the challenge. Some pass (in) thru the window then (out) to the RV. This single decoder arrangement should allow viewing of same channel to all TV's in the RV. We supplement some viewing with Google Chrome Cast ($35.00) for those that want to watch another channel.
Amazon.com: Flat Cable CCTV JUMPER Dish Network and Directv Approved: Electronics
