Originally Posted by rkmavis
We just bought the same model and year. Have you come across any 'funky' things a new to travel trailers owner should look out for?
Have you used it yet?
Make sure you check out your water heater bypass. It is located under the sink in the door on the left that is screwed shut. Make sure you have water in your water heater before turning on.
We just bought ours as well, and have only had it out once. That was the only thing that I had to spend a little time on.
Under the sofa by the bed is a good place to store bedding and bulky stuff that isn't used on a regular basis.
