Old 08-26-2012, 12:35 PM   #1
Camper Less Camping
Cajun Po-Boy's Avatar
RV Bubble Level for Fifth Wheels
When you guys install your permanent level to your rig, do you do it with the slides in or out?
In the past I've always established level with the slides in, any difference doing it otherwise?
Also, do you screw mount into the fiberglass front cap area or using a bracket to screw on the underside? Our unit will have the pinbox shroud cover, not sure if that's the best place to screw and mount the bracket?
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-26-2012, 12:47 PM   #2
Here's how I mounted mine. 1/8" thick alum plate screwed to the bottom of the cap and the level is pop riveted to the front of the plate.
