Old 08-28-2006, 07:48 PM   #11
Bona fide Nut job
Winsurfer76's Avatar
Originally Posted by Bear
Mods I have done to my 5th wheel :
1) Installed thermopane windows (not offerd from factory)
2) Installed 2nd 35000 btu furnace in garage
3) Installed custom aluminum checkerplate cabnets and cloths hooks in garage
4) Installed 2nd window in garage so I can use it as an office on location when I work
5) Remove standard hide a bed and replace with lazy-boy recliners
6) remove standard 27" TV and replace with 37" Plazma TV
7) Install Cruise TV auto aquire satilite TV system
8) Replace 5500 watt Onan Marquies Gold genset with Onan 5500 watt Marquis Platnum fuel injected genset (I had the Platnum in my old trailer)
9) install Heart Interface 3000 watt inverter with 130 amp smart battery charger ( I had an Onan inverter but it was junk)
10) Install 3 100 watt solar pannals with 25 amp charge controller
11) Install 6 Trojan T105 6 volt golf cart battries
12) Install SurFlow 5.5 GPM variable demand water pump
13) Replace factory bed matress with True Form memory foam matress
14) Install 13500 btu air conditioner in bedroom (15000 btu as main AC)
15) Install 12000 btu Olimpic catilitic heater in living area
16) Install Max Air vent covers on all vents
17) install wireless back up camera on rear of trailer (One also on back of truck)
18) Install class 3 hitch and wireing on back of trailer for pulling my Jeep YJ as a towed vehical
There is more, I will just have to think about what else I have done.
Cheers
Bear
You set the bar too high for everyone else. Seriously, those are some AWESOME mods. I've done the memory foam matress swapout and I'm looking at the Max Air covers as we speak.
2005 Wildwood 28BGSS
Winsurfer76 is offline   Reply With Quote
Old 09-06-2006, 08:10 AM   #12
powerboatr's Avatar
Originally Posted by milzat
Click Here to view the Mods & Upgrades I've done on my new TT.
There wil be more to come when I get the time.
What Mods or Upgrades have you done to improve you RV?
You sir get a big ATTA boy
very nice
I have been looking at the plxiglass screen door thing for a while, but intil today never really saw how it was done.
THANKS a million.
our mods is a bit short
deep freeze in basement
central vac
gutter extensions
fabric covered window light blockers
LED reading lights over master bed
Surge gaurd with panel
Relocate genny panel to kitchen vice under bathroom sink ???
insulate forward storage compartment ceiling limits cold feet in bedroom
portable icemaker
relocated rear stab jacks forward 6 feet
computer fans to circulate air under dinette bench seats
max air vents over fantastic breeze fans
Bear, can you give us a run down on teh olympic heater???? this might be just the cure i need in the rear of the coach
i geuss i need to get some pics posted and go get some plexiglass
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 09-06-2006, 11:22 AM   #13
Bear's Avatar
The catalitic heater is a great piece of equipment. I stayed in my trailer all last winter while working up in Northern BC (Dawson Creek mile 0 Alaska highway) the temps got to -40 and a wind chill on top of that. This was in my 36 ft 3 slide Alpinlite only 1 35000 btu furnace, without this cat heater I would have froze. They come in different sizes, if you are just looking to boost your heat level a little a small one will be fine, your furnace won't cycle near as much. The only caution is humidity. The catilist process creates humidity as a by product. I ran mine wide open 24/7 last winter, I had a de-humidifyer running, and I was dumping abut 1.5 quarts of water a day out of it. And it also uses oxygen, so leave a vent cracked. Other than that I would never be without one again.
Cheers
Bear
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
Old 09-06-2006, 12:47 PM   #14
powerboatr's Avatar
thanks bear
we had quite a humidity problem last winter, ran the dehumidifier 24/7 and dumped it every morning
our rig is tight and us humans breathing was flat filling it up with humidty
this year will be differnt, we wil lbe sosuth about 4oo miles where is doesnt get as cold
Old 09-08-2006, 08:51 AM   #15
power, lots of power
Hi everyone,
Just joined the site. We have just purchased a 2007 Rockwood 31 footer. And we are new to the TT world. I would say most of our camping will be dry, and we had to have a generator. Went to Camping World and got 2 Honda ieu2000 with an adaptor, they were great, the weight of them, little, easy to haul. Everything you could ask for except the run time was less than 4 hours. This is not what Honda advertised for these units. So we took them back and boy did we get a genertor then. It is the new Onan Juice Box, it is heavy (around 400 lbs). It has a receiver hitch and on a stand with wheels. We were afraid we could not handle that big of a generator. But guess what it is so easy. First we had to get a hitch put on the TT (another $500.00), then the thing just rides on the back of the TT, you can pull it off and roll it away from the TT when you are camping. It is very quite and it will run 15 hours with a full load. It comes with a 6 gallon tank. So if anyone is looking in to getting one like this, I would highly recommand The Jucie Box by Onan.
susankallen is offline   Reply With Quote
Old 09-08-2006, 12:55 PM   #16
milzat's Avatar
susankallen,
Thanks for the post. I viewed the video a while back.
That is a fine generator set-up. You will not have to worry about not having enough power.
Below are links to the:
Onan Juice Box Page
and
Onan Juice Box Video
milzat is offline   Reply With Quote
Old 09-15-2006, 03:29 PM   #17
WWTT29FKSS's Avatar
Did you have the mattress/box spring contained together in that camper? I'd like to replace mine but wasn't sure if I could do it. How much did the memory foam mattress cost you?
WWTT29FKSS is offline   Reply With Quote
Old 09-15-2006, 04:31 PM   #18
Bear's Avatar
It's just the mattress, no box spring, the only problem is it's taller than the original mattress, but it diden't bother us. The mattress is a fairly high end mattress, it was $1000 Canadian dollars, but that was a few years ago, they are probably a lot cheaper now.
Cheers
Bear
Old 09-17-2006, 04:18 PM   #19
Mrs. Bear's Avatar
The mattress being a little taller isn't much of a problem. For the bed to fit when the slide is in, we just turn back the comforter. The comforter was the only thing in the way.
Mrs. Bear is offline   Reply With Quote
Old 09-30-2006, 10:40 PM   #20
milzat's Avatar
Polaroid 15" tv
Installed Polaroid 15" HD Ready Flat Panel LCD TV, on swivel wall mount, in bedroom.
Replaced 19" tv in entertainment center with 24" tv. Some disassembly required.
Wow,...What a job!!
Similar Threads
Thread Thread Starter Forum Replies Last Post
What mods or updates have you made? ghamblen Modifications and Updates 0 08-27-2006 02:52 PM
