Old 09-21-2008, 01:15 PM   #51
MOD Guy's Avatar
Originally Posted by JSMcRae View Post
Hi!
Somewhere I saw where someone had enlarged the length of the stack of cabinets in their RV. There IS a lot of wasted space there, available for larger drawers, at least length-wise! Does anyone remember WHERE it is?
Thanks!
Are you talking about something like this?
Factory shelf
New cabinet added
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 09-26-2008, 02:03 PM   #52
Wow, that's a great match! Where did you find the cabinet/door, and what was it called? Thanks,
--J&R
JandR is offline   Reply With Quote
Old 09-26-2008, 09:53 PM   #53
MOD Guy's Avatar
--J&R
I built the cabinet to fit using material I ordered from Forest River. The door is a standard size that they make. There was not a door available in the height I needed that would match the width of the closet door below, so I had to use one that was smaller. I left a pocket space to the right of the cabinet, and this is where we store the bunk curtain when it is open. This helps keep it out of the way. The rear area has two shelves for the kids stuff, with plastic bins that we already had. The T.V. is tucked into the rear most area next to the front wall.
High Springs, FL.
Old 09-26-2008, 10:07 PM   #54
Great idea and nicely done. Thanks again.
--J&R
Old 10-01-2008, 10:46 AM   #55
CampeRooo
rthrbelsewhere's Avatar
Originally Posted by milzat View Post
The Tonardo tank rinser work good. Not at all hard to install. I didn't use the hose and clamp that come in the kit. They're kinda flimsy. Best to pick up a garden hose repair end at local hardware store.
If you purchase a Tornado, attach it to a garden hose before installing to see how it works. I did that and it didn't deliver as much water as I'd like so I enlarged the holes at the end of the nozzle. I used a 1/8" drill bit.
Have a good day.
Hey Mike...
I just purchased one yesterday and ran it with the garden hose like you suggested and I noticed that it doesn't spin all that great. Is that essentially why you drilled bigger holes in it? Did you drill out the side holes too or just the end ones on the tip of the "sprinkler". Thanks
joe
rthrbelsewhere is offline   Reply With Quote
Old 10-01-2008, 11:06 AM   #56
cat1956's Avatar
Do you have a Phone Number for ordering parts from Forest River? Thanks
cat1956 is offline   Reply With Quote
Old 10-01-2008, 12:19 PM   #57
CampeRooo
For parts, try Stephanie Little at Forest River slittle@forestriverinc.com
For future reference: http://www.rvgene.com/pages/contacts.html
Old 10-01-2008, 09:03 PM   #58
cat1956's Avatar
That Tornado Tank Rinser sounds great. My tank is a 25 gal. and seems to be made of thin hard plastic. Will the screws hold and not strip out? Thanks
Old 10-02-2008, 08:05 AM   #59
CampeRooo
Well....that remains to be seen i guess. From what i can tell, there's no pressure there at the tank or on the tornado itself, unless the remote connection is connected in a fashion that it causes pressure (sharp turns, kinks, whatever). If it's installed without the remote connection setup, then i can see where the hose being connected and disconnected all the time probably could cause some wear there. However, if the remote water connection hose is installed with it and it never gets removed (really no reason to unless you get a leak from the hose itself), then i couldn't imagine why the screws would strip out unless for some reason something gets snagged during transport. I guess it all boils down to how its installed and routed. I haven't read any posts yet of anyone having serious issues stemming from the installation of a tornado.
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
Old 10-02-2008, 09:57 AM   #60
Send a message via Yahoo to SSport
My most major mod....lol
32X8 foot deck:
SSport is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
What mods or updates have you made? ghamblen Modifications and Updates 0 08-27-2006 02:52 PM
