Old 07-24-2012, 11:34 AM   #1
Night Stone's Avatar
RV Spare Tire Mount
Just out of curiosity, my TV has the truck spare mounted under the truck at the back. I was wondering if I can put the RV spare under the truck spare?
Will this cable system hold up or will it snap?
Is this even doable?
Any thoughts?
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 07-24-2012, 12:56 PM   #2
Timex's Avatar
Where is the rv spare mounted now? Never have liked the idea of crawling under the truck to pull the spare out. And the crank for the truck spare tire is right above the bumper. If you have a trailer hooked up, that could be in the way.
Flat tires only happen at night when it is raining and on a dark road.
But flats don't happen often....do they?
I won't be a happy camper when a flat happens, even if it happens in my own driveway. Having the tools and parts, easily accessable, to get me on my way, would be important.
Timex is offline   Reply With Quote
Old 07-24-2012, 01:02 PM   #3
The RV spare used to be mounted on the back bumper of the RV, but I have a fold up rack there instead. So the spare is sitting inside the RV. I am looking at possibilities, such as under another spare(truck) or making a mount system under the tongue area of the RV
FRF and FROG member
This Space for Rent
Old 07-24-2012, 01:20 PM   #4
TURBS's Avatar
Someone just posted the other day where he used a gm tIre lIftIng mechanism under his camper.
So the cable and winch system under your pickup was mounted under his camper.
Looked sweet.
Maybe he'll post pictures.
Ron
Old 07-24-2012, 01:27 PM   #5
Timex's Avatar
I have seen some TT/5W have the spares under the bottom of the rear of their units. Just be sure it can be somewhat easily accessed when needed.
My first camper was a popup. The spare was behind the gas bottle in the front tongue area. You could rig up something under the tongue area.
Just remember, that will add to the weight up front.
Old 07-24-2012, 01:39 PM   #6
It'll be adding weight up front, one 25-50lb spare RV tire versus what will be stored on rack behind RV compensates for it I think.
What I am asking is, can the cable system on my TV hold 2 spare tires, one for the truck and one for the RV under one lift?
FRF and FROG member
This Space for Rent
Old 07-24-2012, 01:56 PM   #7
Timex's Avatar
I can't give you that answer. I'd say try it. May have to add a 2nd cable/chain for support.
Old 07-24-2012, 02:02 PM   #8
lindy's Avatar
I pulled the spare off the back of my TT and stood it up aginst the front wall of the trk bed and used a ratchet strap to secure there standing up, doesn't move bounce or rattle.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-24-2012, 07:04 PM   #9
Ok, talked to a service manager at chev dealer, the cable can support up to 60lbs, its the other hardware that won't hold up. So this is not an option for 2 spare tires stackd underneath.
And I thought I had a good way to do it, oh well, back to the drawing board
FRF and FROG member
This Space for Rent
Old 07-24-2012, 07:24 PM   #10
DougP47's Avatar
Looked sweet.
Ron
Ron I tried to look for the post but had no luck. I need to find a way to mount my spare because it takes up to much space in the pass through. I would like to see some pic on how other people has mounted there's
Doug
DougP47 is offline   Reply With Quote
