I started by getting rid of the single 12V battery.
Went with 2- high amp hr 6V deep cycle battery's.
I then installed a Xantrex Freedom xi 1000 inverter.
You want the inverter as close to the batteries as possible.
Homade battery cover with vent hose.
From there I cannot take a lot of credit.
The actual removal of old Dometic, install of new Samsung, 120V wiring was done by Brandon and Eric from Quietwoods South RV in Neenah,Wi.
You will notice we brought the frig up 4" off the floor. I wanted it as high as possible.
I also had them wire it so only th refrigerator operates off the inverter.
Brandon is suppose to be E-mailing me progress photo's of the work.
Will post them a a later if possible.
Be sure of ALL your measurements!
We came real close to the kitchen island due to increased depth of Samsung!
C.B.
