Old 06-25-2016, 06:29 PM   #1
Kenny kustom's Avatar
Sabre circuit breakers.
Does anyone know the function of these three breakers?
Name:	ImageUploadedByForest River Forums1466897378.670956.jpg
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-26-2016, 07:15 PM   #2
They are re-settable CB. One protects downstream wiring from battery over amperage and the others probably have things like slides, landing gear etc attached to them. there should be a small reset button on the sides should they trip. If not they are thermal in nature and will reset automatically.
2016 Wildcat 312BHX
2015 Silverado 3500HD
sugarjohnson is offline   Reply With Quote
Old 06-26-2016, 08:07 PM   #3
I know what they are.
I'm trying to identify the circuit of each.
I'm cleaning them all out, and installing a small CB panel.
Time to do the old, disco and test method of indent.
2016 Sabre 36QBOK
Old 06-26-2016, 08:37 PM   #4
Sorry about that....can't help you on what they are for but can tell you I did exactly what you are looking to do with my new 5th wheel. I used a Blue sea fuse panel along with a dedicated ground bus. Good luck, RV wiring is always a treat!
2016 Wildcat 312BHX
Old 06-26-2016, 08:42 PM   #5
The wiring will be better once I am done.
I'm putting a pair of batteries there, along with a new box.
Breaker panel from blue sea.
Magnum inverter and blue sea sub panel.
I can't stand the mess and disorder.
2016 Sabre 36QBOK
Old 06-26-2016, 08:46 PM   #6
2016 Sabre 36QBOK
We think a like...did the same with a pair of 6v trojans. I literally had 5 wires on one breaker and grounds just stacked on a common ground that I could spin by hand. Crappy at best...good luck with the project.
2016 Wildcat 312BHX
Old 06-26-2016, 09:20 PM   #7
I have a pair of J185 12v Trojans to go in.
2016 Sabre 36QBOK
Old 06-27-2016, 12:27 AM   #8
I go RV'ing not Camping
jgourlie's Avatar
This sounds like an interesting project, I am curious to see how it turns out
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
breaker, sabre
