Old 09-04-2016, 01:31 PM   #11
Take it back to the dealer ASAP. Eventually you will have leak problems. My dealer fixed ours without any problem.
otisite2016 is offline   Reply With Quote
Old 09-04-2016, 01:45 PM   #12
Are you talking about it being soft/ saggy just inside the door? Will the dealer fix it or should I just do it myself
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 09-04-2016, 01:55 PM   #13
They lied to you! Youroo!!
As much as as I love a good solid statement like that, why are 90+% built that way.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 09-04-2016, 02:12 PM   #14
Originally Posted by youroo View Post
Maybe your Styrofoam floor is weak? Youroo!
No, it's jus the small gap between the floor and the top of the pipe.
tjmezzan is offline   Reply With Quote
Old 09-04-2016, 02:21 PM   #15
Mr. Dan's Avatar
I had this issue with a previous TT - a Keystone Cougar. I had to shore mine up with scrap lumber... made it solid, though.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 14; booked = 28
Old 09-04-2016, 04:45 PM   #16
Yup Youroo! That awesome! Thanks for the pics, that exactly what I'm planning on doing too!
D-Man is offline   Reply With Quote
Old 09-04-2016, 04:48 PM   #17
Is that Styrofoam on top of your short brace Youroo???
Old 09-04-2016, 06:03 PM   #18
northstar1960's Avatar
Because the manufactures don't give a poop . just get em out the door .
northstar1960 is offline   Reply With Quote
Old 09-04-2016, 07:39 PM   #19
Yes,the OEM make up is "Shower floor/styrofoam/plywood/2x2 leg suports/" this all sets on the 2x2 legs plus the outer perimeter where the access door is also located! F/R removed/cut out/eliminated the RV floor area so the drain would fit,BUT the cut hole is/was WAY to LARGE thus NO support area for the 2x2s,can we say "Mid Air"? I install more styrofoam above the plywood and then built the Bridge over the Hole for the 2 Mid Air legs to sit on! I will not kid you it took a while to Measure/cut/make/install/glue this all up,I really Doubt any Dealer would spend this time to support a shower! Thus members get answers like,"They are all that way"! Youroo!!
Old 09-04-2016, 09:13 PM   #20
Yep I took it back to dealer, they fixed it - no problems now!
Sent from my SM-P600 using Tapatalk
Krlpj05 is offline   Reply With Quote
show, shower
