Old 09-03-2016, 10:16 PM   #1
Saggy floor in shower
Has anyone had the problem of a saggy corner shower floor in their Forest River? My brand new Salem Hemisphere Lite has a nice corner shower in it, but when i went to use it, the shower floor sagged really bad like there is no support under it and sags to the point that I'm afraid of damageing the drain piping. There is a small access panel in the front to get in under the plastic shower floor and I was thinking of maybe sliding a couple 2x4's in on either side of the floor drain to stabilize it. Has anyone else had this problem?
D-Man is online now   Reply With Quote
Old 09-03-2016, 10:28 PM   #2
Yep! Built a Bridge across where they cut out the Floor for the Drain! They could have put 2 drains in the hole they cut! Youroo!!
Old 09-03-2016, 10:30 PM   #3
Here!
Old 09-03-2016, 10:33 PM   #4
And Here!
Old 09-04-2016, 12:13 PM   #5
7 Year Class A RV'er
Same issue in the our Legacy shower - saggy right around the drain. Thanks for the pictures, youroo - just what I need to do!
2015 Legacy SR340 360RB
Old 09-04-2016, 12:22 PM   #6
It is hard to see but where they cut out the floor is where the shower support is located! Youroo!!
Old 09-04-2016, 12:33 PM   #7
I was told it was designed that way to keep too much rigid pressure from causing problems with the drain pipe.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 09-04-2016, 12:43 PM   #8
They lied to you! Youroo!!
Old 09-04-2016, 01:10 PM   #9
Mine has supports right up to the pipes, but I still feel the soft spot when I step in the shower. The pipe is too close to the bottom of the shower to put a bridge across. Even if I could, it would cause pressure against the pipe and there would be no flexibility. Sometimes it's best to leave well enough alone.
tjmezzan is offline   Reply With Quote
Old 09-04-2016, 01:22 PM   #10
Maybe your Styrofoam floor is weak? Youroo!
show, shower
