Old 07-31-2013, 03:03 PM   #1
DougP47's Avatar
Salem bumper mod
I wanted to use my bumper to haul generators and gas. The bumper wall is to thin to carry anything IMHO. Went to my local Reeses Hitch shop. This is what we came up with. I can puta cargo carrier or pull my box trailer if I want.
ID:	36617   Click image for larger version
ID:	36618   Click image for larger version
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 07-31-2013, 03:48 PM   #2
MtnGuy's Avatar
IMHO, yer gonna have some trouble.
I understand that some of the states that do allow double towing, it is only behind a 5th wheel. A trailer behind a bumper pull trailer is going to really aggravate sway.
Any weight added to the trailer bumper is gonna take weight off of the tongue. I figure on my setup, I loose 15 lbs. of tongue weight for every 40 lbs. of bumper weight.
Old 07-31-2013, 04:00 PM   #3
arff2108's Avatar
How heavy
I cannot believe you haven't exceeded tow capacity! how much does all that weigh?
Salem 27rkss
2005 Ram 1500
arff2108 is offline   Reply With Quote
Old 07-31-2013, 04:01 PM   #4
Herk7769's Avatar
Best of luck with that.
I hope it all works out for you.
HAM CALLSIGN - KC3FFW
Old 07-31-2013, 04:04 PM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
Be careful with that setup...someone posted a pic not long ago of a overturned 1/2 ton truck pulling a TT and small trailer behind it on the interstate.
Don't know how the accident occurred but just seems like a lot of train there!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-31-2013, 06:23 PM   #6
DougP47's Avatar
Ragin that's what my friend said when he seen the picture. Probably the only time I will pull the box trailer. Went to flying field with 40 lbs of rc airplans inside wanted to see how it road. But you gota admit it the receiver will pull a bt it will handle my 2 generators and gas to go with it. The was the main idea for adding the receiver, to keep all that equipment outside the tt. Thanks for everyone's input.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 08-01-2013, 08:06 AM   #7
DDC
DDC's Avatar
Looks good although I don't fancy pulling the trailer, what if you ever had to back up ugg, I have been thinking of doing this too a lot of the new "Lites" are coming with a platform/ basket already installed and being able to fold up when not in use, as far as I know the frames have not been made and heavier it's just a matter of cross bracing properly. I know a lot of people talk about warranty being void if you do anything to it but by what I have seen on here getting warranty from frame manufacturers is a whole task in it's self and if the work is done by a qualified dealer then you should have no problem.
DougP47 what did you do with the spare tire? I have been thinking of mounting it behind my propane tanks as I don't have the height to put it below.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-01-2013, 03:25 PM   #8
Tom Wolf's Avatar
I have pulled double before when we had our Nash TT. We had a hitch welded to the frame by a professional welder. They did all the wiring also. In Montana it is legal to tow double as long as both trailers have electronic brakes on them with a break away wire connect according to the Montana Highway Patrol. Mine did not. Had no trouble towing it at all. I was a total of 69 feet long.
2013 Rockwood 2608WS
2003 Chevy 2500 HD Crew-cab D-max
2 Honda 2000 generator's
Tom Wolf is offline   Reply With Quote
Old 08-01-2013, 03:28 PM   #9
RubenZ's Avatar
Try backing up
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 08-01-2013, 03:32 PM   #10
Tom Wolf's Avatar
Yep, I tried once and it did not turn out very good. I would unload the quad and use it to move the trailer. The trailer was easy to move by hand also.
salem
