Old 07-13-2018, 09:13 PM   #1
Satellite Question
I have a 2018 Cherokee 274VFK. I want to add a DISH Tailgater Pro Satellite Antenna Bundle with Wally to my TT. There is only a cable in connection (no satellite in). Can I hook the tailgater Pro to the cable in connection on the outside and then from the cable out by the TV to the Wally or do I need to keep them separate and run a different way. If so thinking about a sealed hole in the back bay door and just have to deal with cable ran through the TT on the floor.
TV: 2014 Ram 2500 Laramie Longhorn
TT: 2018 Cherokee 274 VFK
Husky Centerline TS 1200
PredGunner is offline   Reply With Quote
Old 07-13-2018, 09:51 PM   #2
This is asked on here a couple times a week. You will have to pull the wall plate and do some cable organizing more than likely. Probably have to add another cable -out- by the TV cable wall plate. I just drilled a hole in the wall plate and added the extra -out-that way. There are a few good web pages that give detail on how your cables have to be set up for everything to jive together. Good luck.....
guyster is offline   Reply With Quote
lite, satellite
