Old 11-13-2015, 10:10 AM   #1
Satellite TV question
I am considering getting a portable, non-mounted satellite for the motorhome. I have 3 tvs in my motorhome, 1 in the bedroom, 1 in the main living space, and 1 mounted outside in a cabinet. My goal is to not have 3 tuners, as I'm a freak about minimal clutter lol. If I get 1 tuner/box and tuck it away in the bedroom cabinet, a universal remote that doesn't need line of sight, can I split the output of the tuner back into the motorhomes coax and watch the satellite TV on any tv (realizing they would all have to watch the same channel - which I'm ok with)?
Do I need some special converter to push that signal down the existing coax? Would the other channels just have to be set to the right channel?
If what I'm doing won't work, is there a way to achieve the same solution where I don't have 3 tuners/boxes?
jjlavin is offline   Reply With Quote
Old 11-13-2015, 10:14 AM   #2
A32Deuce's Avatar
You will have to check with the people you buy your service from. More than likely need some kind of splitter. Dish is HDMI. RV's are not HDMI friendly! I have some ideas I am going to look into.
A32Deuce is offline   Reply With Quote
Old 11-13-2015, 10:25 AM   #3
So with Dish, I would just need this to "push" the signal back down the coax? http://www.amazon.com/E-More%C2%AE-D...F0HJXS4GWFMWWR
Old 11-13-2015, 10:31 AM   #4
A32Deuce's Avatar
That should work for HDMI to COAX. I'm thinking it should work back through the connection at main tv. I have a box that I am going to try that brings all signals into it and then sends out what ever signal to what ever tv you are using. Sat. is only one with one box so all tvs same signal.
Old 11-13-2015, 10:35 AM   #5
dan-nickie's Avatar
Depends on what Reciever you use.
Many of them have coax outputs that can do what you are asking.
Of course it will not be HD.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 11-13-2015, 10:38 AM   #6
dan-nickie's Avatar
Reading the description and the questions answered, this will NOT do what you think it does.
Dan
Old 11-13-2015, 10:40 AM   #7
Yeah Dan, I re-read and it's close but no cigar. The output is rca. Hmmm
Old 11-13-2015, 10:46 AM   #8
A32Deuce's Avatar
That one from Amazon is coax out, HDMI in.
Old 11-13-2015, 10:49 AM   #9
dan-nickie's Avatar
If you get DishNetwork, the VIP211K receiver has coax output.
DISH Network MPEG4 HDTV Satellite Receiver/Tuner(DISH211K) from Solid Signal
Then you will need this for the RF remote control.
http://www.amazon.com/Next-Generatio.../dp/B000C1Z0HA
Dan
Old 11-13-2015, 11:00 AM   #10
A32Deuce's Avatar
I have the VIP211S box and that is HD also. K is the newest box. If you have dish at home, you can transfer from home to portable hard drive and use in the RV.
satellite
