Old 01-29-2015, 05:02 AM   #1
Scan gauge Users - I Need Information
I purchased a Scangauge II for our Sunseeker on a 2010 year model E-450 V-10 chassis mainly to read transmission fluid temperature (TFT). I downloaded the manufacturer's list of codes and entered them for this and some other readouts, but none of them work. I've read in this forum that some are getting a TFT readout with their Scangauge.
If you are reading TFT on your Ford V-10, please post the codes you have entered along with your year and model so I can try the codes you are using.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 01-29-2015, 06:25 AM   #2
Mikegjax's Avatar
I don't understand why you need to enter codes. I have the same unit hooked to my Sprinter and it reads anything that is available. If it does not display a specific temp etc. it might be because that info is not available.
Am I wrong in this? Just curious.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-29-2015, 07:09 AM   #3
I had a scangauge on my kia and I could not get it to read the trans temp. I emailed scanegauge and they gave me a couple codes to try but I could never get it to work. You may want to Email scanegauge and see if they have an answer, they were very responsive when I asked.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 01-29-2015, 08:42 AM   #4
The Scangauge displays a number of standard data points but they offer the capability to add more points that are vehicle specific. Mine displays the standard ones okay. I downloaded their code sheet and entered the codes for my vehicle. I get no display for the ones that entered. I have read on this forum that some people are getting additional data points and would like to know what coder they are using and what year model. It may be that later year Fords output the data but mine does not.
I contacted Scangauge but they had no other suggestions.
RamblerGuy
2011 Sunseeker 3100
Old 01-29-2015, 09:40 AM   #5
I programmed mine 4 1/2 years ago but believe it was the Ford CAN codes that work on my 2010 V8.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 01-29-2015, 11:29 AM   #6
RVBikers's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Ditto....I got mine about 5 years ago and I recall something about the Ford Codes. Also, when I bought it, I had to pay a few extra bucks for the extra "X-codes" or something to that affect. Sorry I cant recall exactly but maybe this will point you to in the right direction.
good luck.
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2016 Prime Time Spartan 1242X
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
RVBikers is offline   Reply With Quote
Old 01-29-2015, 11:51 AM   #7
2007 WildCat 32QBBS
05CrewDually's Avatar
On the unit, go into X Gauge using the menu button.
Once there, scroll through and program the exact Ford specific code below:
05CrewDually is offline   Reply With Quote
Old 01-29-2015, 12:53 PM   #8
MtnGuy's Avatar
It is a PITA to plug in all of the numbers, but the Scan-Gauge II has been reading the TFT on my truck for 8 years now.
There were 2 sets of X-Gauge numbers listed when I got my Scan-Gauge. I entered in 1 of the codes (PWM or CAN...can't remember which), and it did not work. I entered the other, and it worked !! If 1 doesn't work, try the other. Ford/Lincoln/Mercury Specific : Linear Logic : Home of the ScanGauge
Looks like 05CrewDually's codes might be for the 6.0 diesel instead of a gasser.
Old 01-29-2015, 08:59 PM   #9
Mt guy
What is the year, model and engine in your truck?
I've tried all the combinations in the list. Which worked for you? I'll try again.
RamblerGuy
2011 Sunseeker 3100
Old 01-29-2015, 09:14 PM   #10
Mnflyboy's Avatar
Keep at it...took me a couple of tries to get mine to work...but it does work. 2007 Georgetown on a 2006 F53 chassis.
Jaye(Mn)
Jaye & Cindy
2007 Georgetown 349 XL
Mnflyboy is offline   Reply With Quote
