02-08-2018, 01:12 AM
Scarce insulation in the attic 2016 Forest River Wolfpack.
While remodeling the master bedroom due to water trapped in the subfloor I decided to take a look inside the attic to check for leaks. Good news is no leaks. Bad news is all the insulation is piled up on the right side!!! Why and where is the rest of it?
02-08-2018, 03:53 AM
Just as confused as you
Sorry to say, but what's on the right side doesn't look like any insulation I've ever seen before. If it is some kind of insulation it's not much.
Richard & Jill
02-08-2018, 06:07 AM
Looks like shredded tires or something !
02-08-2018, 06:19 AM
That is sad!
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
02-08-2018, 06:38 AM
Attachment 161960
#1 it was break time
#2 at the factory.
Put your camera on a selfie stick and get us a picture of that stuff.
02-08-2018, 12:08 PM
Attachment 161960
Dead mice?
Campah
2017 Rockwood 2109s Mini Lite
02-08-2018, 06:00 PM
I would also be concerned with the roof decking pulling away from the rafters on Left. I would send pics to the dealer and manufacturer. Then maybe blow some insulation in there.
02-08-2018, 06:53 PM
Also why is the edge of the OSB even visible in the pic? And how come the joint doesn't fall over a rafter?
Larry Day, Texas Baptist Men volunteer since '01
'13 Silverado LT 3500HD D/A CCSB 2wd, custom RKI bed
'17 Puma 351THSS toyhauler
02-08-2018, 07:12 PM
Obviously any $$ that some of these employees building these RVs are getting paid is way too much. Then again the RV companies are the ones that in the end should be responsible to correct these disasters.
02-08-2018, 07:29 PM
It’s chopped up pieces of seat cushions and vinyl.
This came out of my ceiling. They blow it in so that is why there are gaps where there is not because it gets backed up.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
02-08-2018, 07:47 PM
I didn't see that the first. That is not acceptable.
02-08-2018, 07:50 PM
Crusader insualtion
I have what Prime Time calls the "Extreme Thermal Package" on my 2016 Crusader 321 RES. When I re-configured the bedroom closet I found No Insulation between the back of the closet and the Fiberglass nose of the rig.
So much for quality control and supposed upgrades!
I packed it with insulation and finished my modifications and went on my way. That was less time, expense and aggravation that trying to get the factory to do something about it.
NxChptr
2016 321RES Crusader 5th Wheel
2016 GMC 1500 MaxTow Pkg w/ 6.2 Gas and 8 Speed
Nights out 2016: 20±
2017 153
2018 38 through 2/8/18
02-08-2018, 10:23 PM
Too many high speed left turns moved it over to the right side. Seat material for insulation? What a concept for recycling. I'm afraid to look in my ceiling space now and to see or not to see, that is the question. Thanks for sharing.
02-20-2018, 12:06 PM
I have seen this same shredded material in the plumbing areas of my 2013 Wolf Pack
I haven't opened up anything in the ceiling or walls yet. This isn't very good insulation even if it was packed tighter, air can circulate in this crap. After I bought my RV I saw a post on another forum where a gentleman posted "I wouldn't touch a Forest River product with a ten foot pole" Needless to say getting a bit weary about what I've gotten into. I actually came into the forums to see if any other Wolf Pack owners have done electrical mods. I've found that the power receptacles on one side of my RV are all wired to the same circuit as the power converter while another breaker is left unused. This doesn't seem like good design.
02-20-2018, 04:00 PM
If you have an open slot, just remove the cover and stick in another breaker. The converter wires are routed loose from the circuit board to the breaker panel. They are stranded copper wires while all the other 120 volt wires are romex solid copper. You should see a black romex wire and a green stranded wire going to the single breaker. Just move the green wire over to the new breaker, problem solved.
On my Puma, all 13 inside and outside outlets were on a single 15 amp breaker, with two unused slots. Too difficult to move any, so I just added several new outlets using the available slots. Now I can run electric heaters on the new outlets and leave everything else plugged into the original outlets.
02-21-2018, 08:15 AM
All you can say is......"It's hard to get good help these days!" To the man that said it was quicker to fix the problem yourself, sad but true! And you can trust the work you did! Can't say that for the ones who left that mess! Having said that, I would send those pictures to the upper management with a note about people checking the work to be done (quality control or the lack thereof) and ask Who dropped the ball on that one! Good Luck!
09-04-2018, 05:15 PM
X2 on afraid to look but I'll make myself do it now.
On our last outing my infrared gun showed inside ceiling and wall temperatures higher than the temperature outside and we were parked in the shade so not impressed with the insulation, if any. For some reason I was under the impression these things have fiberglass and foam laminated walls and ceilings.
The photo of roof decking pulling away is what I imagined when on our roof hearing it squeak and give under my feet. Could it be because at that spot I am standing between two 14 inch holes (AC and vent) with a skylight hole to my left? I avoid walking there now.
Behind the AC between another vent adjacent to another skylight is very solid so not sure what's going on.
Then I remember I bought an entry-level RV and I'm not camping in a tent and try to stop picking it apart and enjoy it.
This, in no way, is meant to belittle anyone else's concerns about their rig... it's how I deal with it. [emoji23]
Kirk
2017 Forester 3051S
09-04-2018, 05:57 PM
For some reason I was under the impression these things have fiberglass and foam laminated walls and ceilings.[/QUOTE]
The walls if fiberglass do have 1" Styrofoam board between 2 1/8 luan and then a 1/6 of fiberglass on the outside . well insulated no but better then nothing , now the roofs are another story .
