Old 05-01-2013, 03:08 PM   #11
Phat Phrog Physician
SabreDoc's Avatar
What the hell's a clevis?
Sounds like a southern boy's middle name to me.
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
SabreDoc is offline   Reply With Quote
Old 05-01-2013, 03:13 PM   #12
Originally Posted by B47 View Post
True - they are cheap. But being a man of high standards and a reputation for doing things right ( at least according to Turbs) wouldn't you rather have a neat,clean and mechanically sound mechanism here on your RV?
You probably wouldn't have to replace a threaded rod and clevis ends as often as a coat rod.
I don't really care if he uses string or a coat rod - it is a good idea.
Poking fun B, I would do as you suggested also.
Clevis is an attaching device that has 2 legs with a hole for a pin and the end opposite the legs is threaded. Not a southern thing, even the Yankees use them.
Old 05-01-2013, 03:13 PM   #13
B47
Doc
Can't show you a pic, maybe someone else can, but a clevis is a U shaped fitting that has a hole drilled thru the open end and is threaded on the other end end.
Old 05-01-2013, 03:18 PM   #14
B47
Yeah "even the Yankees use them." We used them on the farm to attach the "O" shaped attachment of a farm implentiment ( plow, disk etc) to the drawbar of a tractor.
Old 05-01-2013, 03:21 PM   #15
SabreDoc's Avatar
Ya sure, except we call them a U-shaped attachimadoohickeythingy.
Clevis just sounds weird.
Doc
Ron, Amber & Jordan
Old 05-01-2013, 03:25 PM   #16
B47
Doc
Funny but calling a clevis a "U-shaped attachimadoohickeythingy" sounds weird to me
Old 05-01-2013, 03:26 PM   #17
Herk7769's Avatar
Radio Control vehicles use threaded rod and clevis to make adjustable connections. Also called "pushrods."
Hardware & accessories.>Horn/Hinge/Clevis
E-flite Pushrod Set [EFL2730] | RC Airplanes - A Main Hobbies
HAM CALLSIGN - KC3FFW
Old 05-01-2013, 03:38 PM   #18
B47
Lou - thanks, but I must take exception to you saying clevis are "Also called "pushrods."
Pushrods are the tubes that the clevis is attached to. The clevis is a component of a pushrod. They are, as you correctly say, adjustable.
Old 05-01-2013, 04:02 PM   #19
Herk7769's Avatar
OK
Old 05-01-2013, 04:32 PM   #20
And naturally I have to take exception, pushrods are hollow tubes that sit on lifters and rest in sockets on rocker arms in engines to operate the valves.
