Old 06-22-2016, 01:06 PM   #11
Ok, Ok, Seriously thanks for the heads up.
SubVet is offline   Reply With Quote
Old 06-22-2016, 01:12 PM   #12
Left Coast
Hot water tank also, and bumper end caps...
Sent from my XT1585 using Tapatalk
Old 06-22-2016, 01:39 PM   #13
wire screen cut just over size, when pushed in from the front, the cut edges act as little barbs on the plastic and hold forever,....... also other vents can be covered with a bead of caulking around the area on underside, press wire screen into wet caulk, can hold in place with any tape, when caulk is dry, you have a permanent fix,..................
ID:	111813   Click image for larger version
ID:	111814   Click image for larger version
ID:	111815   Click image for larger version
fella10 is offline   Reply With Quote
Old 06-22-2016, 02:14 PM   #14
Thanks for all the suggestions. I just went up on top of my TT, guess what.. Wasps (3) came out of the air conditioner vents when I went to open it up.... Looks like I am going to have to deal with that too
Old 06-22-2016, 04:17 PM   #15
Stormrider151's Avatar
Wait until they get in the front cap of your trailer. I noticed they were very interested in the underside of my trailer at the front. Crawled under the trailer and found a 1/4 gap. I don't know that they are in there for sure but I do have access through the pass through to check. Expanding foam took care of the gap.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-22-2016, 04:38 PM   #16
screens in reefer vents
Dont forget tank vents daubers have plugged mine
JR Smith is offline   Reply With Quote
Old 06-22-2016, 04:45 PM   #17
Left Coast
Quit using rose scented water!...lol
Old 06-22-2016, 04:48 PM   #18
Dont forget tank vents, daubers plugged mine.Take off cap and put plastic screen over pipe ,reinstall cap.
Old 06-23-2016, 10:06 AM   #19
NCBBA11043's Avatar
What about air flow restrictions? Those screens cut down airflow by at least 50%?.
2015 Silverado 3500HD CC Long Bed Diesel
2016 Silverback 33IK
NCBBA11043 is offline   Reply With Quote
Old 06-23-2016, 10:12 AM   #20
Using screen wire and airflow is not a problem as most are vastly oversized. Fans on the back of the frig more than make up for any flow restrictions.
vent
