Old 06-23-2016, 09:36 AM   #21
I also wonder about air flow restriction - otherwise why would not insect proof screens come standard from the factory instead of the usual larger opening vents?
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 06-23-2016, 09:42 AM   #22
Left Coast
Sent from my XT1585 using Tapatalk
Old 06-23-2016, 10:06 AM   #23
NCBBA11043's Avatar
Anyone have an indoor fireplace at home with screens in the doors? Doors closed, some heat - doors open, inferno. Screens will cut back significantly on air flow, especially if it is gravity (refer). Best solution is to provide twice the amount of surface area of the screen. For example: let's say the one of the refer grill opening is 2'x3". That gives you .5 sq ft. Instead of a flat piece of screen, you need to build a box 24" long by 3" wide by 2" deep (+/-) to give you the surface area you need. Take a look at the covers for furnaces - they are domed shape to give the required surfaced area.
2015 Silverado 3500HD CC Long Bed Diesel
2016 Silverback 33IK
NCBBA11043 is offline   Reply With Quote
vent
