Old 08-16-2014, 09:18 PM   #11
Too Tall's Avatar
I just mounted a rack on the back wall in the bath. I didn't hear any giant sucking sound when I screwed into it.
I just used regular screws and it looks like it's holding ok for now. Since the wall is paper thin and then Styrofoam, I may have to replace the screws with Molly screws however if the wife gets carried away with loading the little rack.
I want to add some shelves to the sides but not sure how to find the studs without buying one of those expensive stud finder that finds aluminum. I wonder if they work.
Too Tall is offline   Reply With Quote
Old 08-19-2014, 07:06 PM   #12
industrial strength VELCRO!!
R & S
2010 Georgetown
2012 Honda CRV toad
rstoro is offline   Reply With Quote
Old 08-25-2014, 02:00 PM   #13
Although I'm late to this thread, from my sailboat experience -
Foam core with fiberglass skins is a proven method of building a fairly strong structure (much stronger than the fiberglass or foam by itself) at a light weight. The glue bond between foam and fiberglass is critical to the composite structure's strength, which is why a vacuum is pulled during the gluing operation (as others have said).
The strongest attachment methods are
a) through-bolting with good-sized backing plates on both sides to spread the compression load over the thin fiberglass skin. Bolt holes should be caulked/sealed to prevent water intrusion into the foam and/or glue joint.
b) removing gel-coat, and expoxy glueing on a wood (or metal) mount plate to which the accessory is screwed.
Neither method lends itself to being reversed very well - although it is easier to fill empty bolt holes than remove a mounting plate.
just my experiences
Fred W
pgandw is online now   Reply With Quote
Old 08-26-2014, 10:34 AM   #14
Too Tall's Avatar
just my experiences
Fred W
Thanks for the info. Do you see any issues screwing things (molly screws, etccc) into the thin inside wall of the RV to install a shelf. I can't see how this could possibly do damage to the structual intergrety of the wall? (assuming you don't drill all the way thru to the outside, ha)
Old 08-26-2014, 06:42 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
We have used Command Strips for most of light weight items and has worked well. Planning to use a couple of screws and Command Strips for a shelf over the bed.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-26-2014, 07:05 PM   #16
Too Tall's Avatar
Command strips, thanks. I must admit, I had to look that up as I didn't know what that was but it's a great idea. We have one in the shower holding up a pretty heavy rack of shampoo etc... and has been there for years. Thanks for the tip!
Old 08-31-2014, 09:37 AM   #17
Too Tall's Avatar
Here's how I added some shelves to a hanging clothes cabinet. It's ok to be critical, I want honest opinions and recommendations as I want to learn from everyone's input.
RV Shelve Project - YouTube
Old 09-08-2014, 05:18 PM   #18
2014 XLR 27HFS
Originally Posted by Too Tall View Post
... not sure how to find the studs without buying one of those expensive stud finder that finds aluminum. I wonder if they work.
Push on the wall with your thumb. It will not give where there are studs. Just take a look around it when you find one to make sure it isn't a pipe or electrical behind it.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 09-09-2014, 03:12 PM   #19
Too Tall's Avatar
unfortunately, that doesn't work on my type of wall which has foam behind the wall so it's all hard. plywood, foam core and fiberglass outside.
Old 01-19-2015, 10:23 AM   #20
2016 Avenger 26BH
Hi you may want to have at a look this thread "Salem Cruise Lite 195BH TV mount"
there are a few ideas on how to solve your concerns.
Cleon is offline   Reply With Quote
