Old 10-07-2015, 09:18 PM   #1
What type of screws do you recommend using to install a exterior cable hook-up on a 2013 Sunseeker?
Jagspe is offline   Reply With Quote
Old 10-07-2015, 10:41 PM   #2
BooBoo23's Avatar
Take a screw out of something else that is attached to the outside (outside power outlet/clearance light/tail light) and use one similar in length and size and you should be OK. There is no weight to a cable port so all you need is something that will keep it firmly attached to the sidewall. Since you have fiberglass walls you should drill a small pilot hole first to reduce splintering where you put the screws in.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23
Camped 2015 - 47
Camped 2016 - 51 done - 6 more planned so far
BooBoo23 is offline   Reply With Quote
Old 10-10-2015, 12:29 AM   #3
Dabmeb's Avatar
Use stainless steel so you don't get rust streaks
Dabmeb is offline   Reply With Quote
