Old 08-03-2011, 11:42 AM   #61
Have you seen this stuff? Airkrete
Supposedly this stuff has great insulating properties, is pest and mold proof (not just pest & mold resistant but pest & mold proof). Think I will check into this stuff, but I don't think it's available in DIY form, you have to pay an installer.
HomeGrown is offline   Reply With Quote
Old 08-03-2011, 12:51 PM   #62
Villa Estate 392FLFB
The_Stuff's Avatar
looks good. wonder if its north of the border though..
also i have slides.. just thought what do i do about the cap slides would have for the open/close part. i think that i could just tack up the styrofoam board probably. lucky you with no slides lol
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 08-03-2011, 05:22 PM   #63
Yep, it's in the frozen north as well, I saw a brief post when I did a google search that someone in Canada had it done and the price was competitive.
I would love to have the extra room with a slide, but glad I don't have it, as it would no doubt have been another hole to pour $$ into getting fixed.
Old 08-03-2011, 05:41 PM   #64
The_Stuff's Avatar
LOL like the way ya thinking
Old 08-03-2011, 05:45 PM   #65
Hey Stuff, I noticed you replaced your thermostat in the trailer. Do you need a specific type for a travel trailer or will a standard residential unit work?
Old 08-03-2011, 05:46 PM   #66
The_Stuff's Avatar
it was standard residential. NDJollyMon has a tutorial on his thread of his trailer. search 392flfb
Old 08-19-2011, 09:59 AM   #67
The_Stuff's Avatar
well finally got a break and found a set that will fit! even without removing the shelf!!
(110 v washer and 240v dryer)
Old 09-20-2011, 01:44 PM   #68
The_Stuff's Avatar
Was trying to see if i could wired in my 240v dyer but it seems i will need to run another cable from the box to the trailer. No big deal i guess. going to run a 20a 110v line aswell for the washer so i dont trip any breakers. As for plumbing it seems that hooking up the water lines will be little to no problem. the drain could be interesting. Going to make a P trap inside so it wont freeze obviously and the go through the floor and out to the sewer. undecided if make its own line or route into the grey water line.
Old 10-09-2011, 10:10 PM   #69
The_Stuff's Avatar
well finally they are installed!! took awhile and many after work breaks.
there was two existing hookups by the hot water heater for the factory installations.
went up and over the drawers and later installed the ball valves above the water heater
then came out the wall into the closet/laundry area.
Old 10-09-2011, 10:10 PM   #70
The_Stuff's Avatar
took the "oh god i hope i know what i am doing" breath and made the holes
ran the wires up for 120 and 240v and put the drain pipes in (not glued yet)
all wired up and plumbed in
had to take the bathroom door and framing for it off to get the washer and dryer in
