Forest River Forums
Sunline User Photos
Old 09-22-2010, 11:31 AM   #1
Villa Estate 392FLFB
The_Stuff's Avatar
Setting up for long term stays (years)
So I finally got a lot to put my trailer on!!! I am going to put 16" blocking under the trailer, probably about 5 sets or more (40 ft trailer), remove the wheels, and take the front V hitch off (4 1" bolts and it comes off).
So, I want to move the water and power hookups from the side wall to have them go through the floor of the trailer. I plan to leave the slides out permanently and skirt the whole trailer with plywood, foam board and siding. That is to ensure that it will not be an ice cube in the winter lol! Has anyone ever re-routed the water and power? anything I should be cautious of? floor joists/paneling etc?
Also Sewer!! My trailer has the black tank just over the front axle, and the tube comes out and over the axles with a valve there, then goes to the back and meets in a V with the grey water with another valve there for each. My question is if the black and grey water pipes are just normal black PVC pipe? I would like to shut off the sewer and drain the grey water then re-plumb them to the sewer hookup that will be firmly under the trailer and in the skirted shelter and I am going to run heat tapes along the pipes and under the tanks to. self regulating kind i think so that it only heats where it need to heat.
any thoughts or opinions?
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-22-2010, 11:47 AM   #2
Moderator
Hello, can't help with much but no need to heat the sewer pipes. As long as they run downhill, they will never have any water in them anyway. Depending on the trailer, most of the drain lines are standard size. Good luck with the rest.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 09-22-2010, 11:50 AM   #3
The_Stuff's Avatar
hmm true. never thought of that. I might heat a trap if i put one in for the black water.
Old 09-22-2010, 03:50 PM   #4
Something to check up on .... If your "permanent" site is part of an organized RV resort (even if you own the lot), there may be bylaws that prohibit the removal of the wheels and hitch. This is the case with at least some of the resorts in our area here in the Pacific Northwest (BC and Washington state). Not sure of the reason for this but may have something to do with fire regulations.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 09-22-2010, 03:51 PM   #5
The_Stuff's Avatar
its a requirement of the place actually for the wheels and hitch to be removed. more so the hitch. the wheels are usually hidden by skirting.
Old 10-04-2010, 02:05 PM   #6
The_Stuff's Avatar
Well got it moved into place last night. Got the 2' 4x4 blocks into place and got it initially leveled. Next is skirting and then a fence for the yard to keep the neighbourhood kids out >
16 12' 4x4's
all cut to 2' lengths and toe screwed together and 21" tall
And in place. of course after the sun is long gone lol
gonna just make my skirting cover the connections box and make it all insulated and so forth.
Old 10-19-2010, 11:09 PM   #7
The_Stuff's Avatar
Well first problem so far. The black water tank is filling up and plugging and not draining.. guess its time to clean it out and take it out. I guess it wont work for my purposes...
Also for heat I have a plumber coming to switch the suburban p-40 furnace to natural gas. It will be nice to have good heat on demand rather then ration 60lbs of propane.
As for skirting I am going to go with wooden framed 2x2 structure with rigid foam insulation behind plywood. Hope to make it look neat and tidy with some matching grey tin on it either this fall or next spring.
Old 10-20-2010, 10:15 AM   #8
Moderator
On removing the black tank..... I know you can remove it, and connect your toilet straight to the sewer. This will cause some smell when you flush. If you put a trap in, I would think that the trap would fill with solids and paper very quickly and become a problem. As for the tank filling up and plugging, are you closing the valve and waiting for the tank to become full before you dump it? You should NEVER leave the black tank valve open all the time. Remember water is your friend, and on a permanent site, use plenty when you flush. And then use some more. Just a thought, and I may not know what I'm talking about, your results could vary.
Windrider,
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
Old 10-20-2010, 10:27 AM   #9
The_Stuff's Avatar
I am waiting till its full but thats the problem. pulled the plug and not everything went down... i think im gonna try to find a flush king and work it that way..
Old 10-21-2010, 09:18 PM   #10
The_Stuff's Avatar
saw this today. think its gonna be a good inspiration for me. something to get thought of winter and patio doors out of my mind lol
» Online Users: 529
78 members and 451 guests
02 rockwood, 4bnabird, 4Jeeperz, 8261ss, backpacker3, Barnman1, Bearcat55, bfisher82, bob7794, bouldercamper, buzzmonster, campfun, CampinQueen, carsonizik3, ClampNfish, cstover, depo, djorgensen3, dlmurray51, DonCath25ds, DonG, donh, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, Freds342, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, kgmat, KKapa, Mad4sax, mcdiver, Mike G, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, Pa-cj5, patov6, Pinesman, Poppy Bill, PrairieBoy, prof_fate, punkaccountant, RattVader, RichN, Riva, Roamin Ovum, rschroe, Rsgtivr6, Rugged Brown, Russ, ryoucrazey, seatosea, ses, Sparkbark, SpringerPop, tfennell81, Tom993, tonybab, transamz9, troyt, UPGRADER, vp22er, Walke, wbdvt, Whiskeyjack, Whiteknight, whj77372
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
