Old 06-21-2018, 07:01 PM   #1
FR27's Avatar
Sewer Hose Storage Install
Here is my sewer hose modification I did today. It fits both my 15' hose with attachments and my 10' extension.
2018 Ford F250 Lariat Trim, 4x4, 6.2L Gas
2018 Forest River Rockwood Ultralite 2706WS
WDH: 12K Equalizer
FR27 is offline   Reply With Quote
Old 06-22-2018, 05:18 PM   #2
1stepcloser's Avatar
I have looked at that in comparison with the home built fencepost versions and like the appearance as well as the locking end caps. Have you found any flex in the middle of the tube where the two parts overlap?
2015 Rockwood Roo 23IKSS
2015 Chevy Silverado LTZ
1stepcloser is offline   Reply With Quote
Old 06-22-2018, 10:49 PM   #3
Fluffywhitedogs's Avatar
I have a similar one and love it. But recently, after a couple years without issue, one of the ends popped open during travel and when I got home, one of my connectors was gone. Now I have carabiners on both ends!
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
Old 06-23-2018, 09:01 AM   #4
FR27's Avatar
I had a little bit, about 2mm from the slide part. I wrapped the intersection where the two pipes slide with black Gorilla Tape. Now its solid and no sliding.
WDH: 12K Equalizer
Old 06-23-2018, 06:21 PM   #5
Sewage hose storage.
Why don't people store sewer hose in the bumper.. Dad did that for years.. I've done that .. My neighbor didn't know that hose could be stored in bumper.. what's the issue?
Maybe you folks are talking motor homes.. I'm referring to tag alongs...
thom125 is offline   Reply With Quote
Old 06-23-2018, 06:42 PM   #6
My first hose wore out in under a year from the rough interior of the bumper. And it was a pain carrying attachments in a tub. Some people say theyíll fit in the bumper but I never had any luck.
Carmen and the pack
Old 06-23-2018, 07:28 PM   #7
I donít have a bumper on my Cedar Creek. I store my sewer hose I a plastic container I brought from Walmart. Everything sewer goes in that container. My water hoses and all things water goes into another plastic container. I store the containers in my basement
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 06-24-2018, 01:24 AM   #8
Why don't people store sewer hose in the bumper.. Dad did that for years.. I've done that .. My neighbor didn't know that hose could be stored in bumper.. what's the issue?...
After reading about the problems about storing the hose in the bumper, i.e. the rust inside the metal bumper, the difficulty of trying to keep the metal tube clean and rust free and abrasion to sliding the hose in and out of entire length of the bumper, I built my fence post storage with a pvc gutter insert. Rather than mounting the tube under my TT, I mounted the 5x5 tube on top of the 4x4 rear bumper, painted it black and applied safety reflective tape. I was concerned with mounting under the TT DUE to clearances and road debris. Mounting on top gives me easier access since I have difficulty getting down on my knees.
johng4706 is offline   Reply With Quote
Old 06-24-2018, 02:25 AM   #9
I used leftover vinyl siding, trimmed off the top and bottom edoes so I only had flat vinyl. I think the inside is a little under 4" so I scored the length to the left 3 inches leaving most of it not cut through so it could act as a hinge. The next scoring was the bottom then the other side. The perfectionist might paint the inside of the bumper, not I. Insert newly made liner, check the end covers have space to seal load all the hose that fits.
I find most of the abrasion is due to the rusty innards rubbing on the hose. This gives a softer and smoother surface. Periodically pull out the liner, rinse the bumper and let it dry.
Timtation is offline   Reply With Quote
Old 06-24-2018, 03:40 AM   #10
Just a member
kandl's Avatar
Many folks do. We do. Got a 15 ft and 10 ft (extension) RhinoFLEX in the bumper. They've been stored in the bumper for almost seven yrs and are none the worse for routine wear and tear.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge 1500 (the Beast)
kandl is offline   Reply With Quote
storage
