Old 09-18-2018, 11:18 AM   #1
tom39's Avatar
Sewer hose storage tube
I have seen others that utilized vinyl fence posts and gutter to store their sewer hose and I really liked the idea so I thought that I would give it a try.
For the spot that I chose to mount the tube, I needed to make a mounting bracket that would drop the tube 1.5" from the belly of the trailer. So using the material I had lying around, I cut some 1.25" square tube which provided me the drop that I needed and a length of 1/4" flat stock which I used as the mounting plate. I then cut and bent some 1/8" flat stock to wrap around the post and welded it all together.
To keep it from rusting, I finished it with some rattle can spray in bed liner.
Next the vinyl post and gutter was cut to length and I bolted it all to the belly of the trailer.
To secure the post caps, I riveted the right side to permanently secure the cap. The left side, I drilled a hole on each side of the cap. Then I cut to length some round stock which I machined a grove on one end so it would accept a circlip and the other end I drilled and used a hairpin to secure it all in place.
To keep things separated in the tube, I cut some PVC trim boards to the reveal of the gutter and snapped them onto place.
So far it seems to be a great mod and I will give it a try this week. My only problem with it all is that because I chose to place the tube against the landing gear, my JT strong arms won't all me to fully raise my landing gear feet. When fully raised, the landing gear feet are held down about 2.5" from being fully retracted. I really hope that this does not result in a problem.
Anyway, here are some pics.
ID:	186894Click image for larger version
ID:	186895Click image for larger version
ID:	186896Click image for larger version
ID:	186897Click image for larger version
ID:	186898Click image for larger version
ID:	186899Click image for larger version
2011 Rockwood 8288 SS UL
2012 Chevrolet 2500HD 6.0l
B&W Turnover Ball w/Companion Hitch
tom39 is offline   Reply With Quote
Old 09-18-2018, 11:38 AM   #2
K2Kevin's Avatar
Looks perfect! Nice work.
K2Kevin is offline   Reply With Quote
Old 09-18-2018, 11:41 AM   #3
Life is great's Avatar
Very clean looking
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - 42 + scheduled....
Life is great is offline   Reply With Quote
Old 09-18-2018, 01:50 PM   #4
tom39's Avatar
Originally Posted by Life is great View Post
Very clean looking
Thank you!
Old 09-19-2018, 02:28 PM   #5
That was an excellent idea, particularly the slide-out tray aspect of it! It can be difficult getting the RHINO brand sewer hoses and accessories to fit in some of the existing set ups. I have the typical Valterra EZ Hose Carrier tube, and I still had to grind down some of the tabs on the orange collar to get it to fit. Your idea is way better.
Scott
SE Michigan
17 Wildwood / 17 Silverado 1500
Mud Hunter is offline   Reply With Quote
Old 09-19-2018, 03:04 PM   #6
mule's Avatar
Tom39, beautiful job! Thanks for the picks, thatís my new #1 winter storage mod!!!
mule is offline   Reply With Quote
Old 09-19-2018, 03:08 PM   #7
MilCop4523's Avatar
nice job
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 09-19-2018, 03:27 PM   #8
Great job.
rlh1957 is offline   Reply With Quote
Old 09-19-2018, 05:10 PM   #9
Nice job , I wish I had used fence post , I used 6in pvc an extra one for the mat
Big Bill is offline   Reply With Quote
Old 09-19-2018, 06:30 PM   #10
Nice clean job Tom. Looks good!
Chazman is online now   Reply With Quote
storage
