Old 06-25-2011, 06:50 PM   #1
Cyber Phrenologist
Radio's Avatar
Shading the shower sky light
During a storm a while back a hail stone cracked the outer "bubble" of my shower skylight. The patch I made seems to be pretty well water tight. I had taken the inner panel down to allow things to dry out and to inspect for leaks. With the major thunderstorms we have had of late, I am now certain there are no leaks and it's time to put the inner panel back up.
Then I had a thought. Since the sunlight coming down through the skylight is so intensely bright and heats up the trailer, too, why not temper it just a bit while we have the skylight apart?
I needed something just laying around, something paid for that I don't have to go get. After some scratching about, I came up with, get this, parchment paper. (Bakers paper)
First I cut a piece to fit the clear opening in the panel. Then I discovered that no kind of tape will stick to parchment paper. I didn't want to use a permanent adhesive either. So I just pulled a large piece off the roll and stuffed the whole thing up in there.
Now the light is not near as bright and is softly diffused. And cost me nothing but some time.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-26-2011, 07:27 AM   #2
Herk7769's Avatar
Awesome idea.
I wonder how a coating of white latex paint on the outside would work?
HAM CALLSIGN - KC3FFW
Old 06-26-2011, 10:58 AM   #3
MrT
MrT's Avatar
Cool! I didn't realize that the inner surface was removable. I'll need to take a closer look at that. Any specific details I need to keep in mind?
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 06-26-2011, 11:12 AM   #4
2Susan's Avatar
Actually what will stick to it is frosting - So when you are working with parchment paper in the kitchen you put a dab under each corner to hold it in place. Royal icing would wash off later (unlike some adhesive products). So what I'm suggesting here is something sticky that will dry hard. Royal icing is incredibly easy to make - it's an egg white beaten until frothy (and a dab of vanilla/almond extract/lemon juice) and then enough powdered sugar beaten in to make it the right consistency. So I'm suggesting making some lovely cinnamon rolls in the rv's oven with delicious royal icing and then using a couple of dabs to hold that parchment paper in place. Royal icing is the nifty icing on sugar cookies that dries hard that you decorate.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 06-26-2011, 03:47 PM   #5
Cyber Phrenologist
Radio's Avatar
Originally Posted by herk7769 View Post
Awesome idea.
The inner part of the sky light (at least in my case) is held in place by screws run up into the ceiling. Remove those and you have access to the underside of the exterior "bubble". There is no seal or gasket material to deal with.
As for paint, I think I'd paint the inside of the bubble, not the outside, as it would no doubt last longer. And I'd use something made for plastic. Latex would probably peel right off, which might be an option if you are unhappy with the end result.
KU4OJ
Old 06-27-2011, 01:23 PM   #6
RubenZ's Avatar
I agree about skylights allowing so much heat and light in, what I find odd is the shade pull is white, so it doesn't really block light lol. They should have made a darker shade instead of the white.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
