Old 05-17-2012, 02:49 PM   #1
Shock Mounts on Alko Torsion Axles
Anyone interested in a kit for installing shocks on the Alko Torsion Axles?
Old 05-17-2012, 03:25 PM   #2
Herk7769's Avatar
Do you have a link on how its done?
HAM CALLSIGN - KC3FFW
Old 05-17-2012, 03:34 PM   #3
No, but I just spent about an hour laying under the trailer and by changing the spindle attaching bolts to some about 1" longer, brackets can be made to bolt on behind the spindle and go straight up to the frame. Using the axle mounting bolts, another bracket can be bolted on. Would have to use the eye type shocks. Am looking at Monroe shock lengths now. The question I have is how much travel from normal would be needed? Suggestions welcome.
Old 05-17-2012, 03:44 PM   #4
Herk7769's Avatar
The web site has some info that I downloaded as it applies to trailer weight and deflection. That might help you.
Old 05-17-2012, 03:59 PM   #5
Thanks, do you know which axles we have under our 5vers? I will use the distance of load to shock load and double it for finding the right shock. May add 1" both ways. 1/4" maybe 3/8" plate is all that is needed other than the gr 8 bolts, etc. Once the plates are made, should be an easy install. Worst part is jacking up the trailer and taking off the wheels.
Old 05-17-2012, 04:03 PM   #6
Herk7769's Avatar
My Flagstaff has two U-40 Al-Ko axles. (4000 pounds each)
Old 05-17-2012, 04:08 PM   #7
Where do you find the rating? Brochure or on the axle?
Old 05-17-2012, 04:19 PM   #8
Herk7769's Avatar
There was a metal tag on both axles about in the center.
Old 05-17-2012, 04:33 PM   #9
Just looked, mine has a sticker with U40 ------ on both axles. Thanks.
Old 05-17-2012, 04:41 PM   #10
Another rat in the race
jar3316's Avatar
Would mounting shocks help with sway side to side or bounce up down or both like my little guy (compared to yours) doesn't get much sway but slowing down the bounce might be nice.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
axle, led pad
