Old 11-21-2012, 08:24 PM   #1
textman's Avatar
Question Shorter 50 amp power cord
My mom just traded her TT for a new one. This one came with a 50 amp service. The 25' cord is too heavy and too long for her needs. Does anyone make a shorter 50 amp power cord? 10' would be perfect. Is this something i would have to customize myself?
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 11-21-2012, 09:06 PM   #2
25' is about the shortest 50 amp cord I have found. You can get a replacement connector (Adventurerv.net) for $81 and cut the cord to length, but that may be too short for most campgounds. Quite often when visiting relatives we use a 30 amp cord (much lighter) with adapters and connect to their clothes dryer outlet, runs everything except the second a/c; have also done this at CG that don't have 50 amp available.
Sirsea is offline   Reply With Quote
Old 11-21-2012, 09:48 PM   #3
our new trailer also came with 50 amp service, and you are right about it being to heavy and too long! At most RV centers you can get either a 1 foot or 25 foot 30 amp cord with the 50 amp twist on connector at the trailer. I am assuming the cord that came with the trailer is not hard wired into the trailer and that it has an outside receptacle were the 50 amp normally attaches.
prairiecamper is offline   Reply With Quote
Old 11-21-2012, 09:57 PM   #4
just re read your post and realized you were looking for a shorter 50 amp cord, and I suggested a lighter 30 amp cord adaptors. sorry probably not what you are looking for!!
Old 11-21-2012, 09:59 PM   #5
Our FW also has 50 amp service to provide for a 2nd AC and the washer/dryer hookup. Since we don't have or use these higher current appliances and depending on your own 50 Amp usage...This may help you too. We use this 30 amp RV Power Cord that connects to the 50 Amp Marinco Locking Connector which I am asuming is what you have too.
The advantage is that even though the cord is still 25' long it is much lighter than the 50 amp counter part. Easier to store and use. Just remember...It WILL NOT provide 50 amps if that is needed.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 11-21-2012, 10:01 PM   #6
Dave_Monica's Avatar
The downside of shortening is that you have to park where the camper's outlet is close enough to the service post, not where you would like to position it on the site. I don't see any standard out there of where the service post is positioned on sites and think that a 10' cord is always going to work.
Dave
Old 11-21-2012, 10:28 PM   #7
Twisty's Avatar
If it were me, I would buy 2 or 3 sets of connectors and make 2 or 3 10 foot 50 amp cords.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 11-22-2012, 06:49 AM   #8
Herk7769's Avatar
The downside to this idea (while it does have merit), is the connections are not waterproof and could be a shock hazard; the extra connections are places where resistance could increase due to corrosion and tip burning and the resulting voltage drop would be much higher than in a straight run of the same length; and you would still need to man handle and store all that wire.
HAM CALLSIGN - KC3FFW
Old 11-22-2012, 07:25 AM   #9
I'm with Herk on this one... camp safe. Here is an idea for you, check out the Easy Real. Shop it around on the net. Hope it works for you.
MorRyde Easy Reel - Power Cord Reel - PPL Motor Homes
grayfox is offline   Reply With Quote
Old 11-22-2012, 10:28 AM   #10
silver's Avatar
can you mount a cord reel? I have one and they are great.
silver is offline   Reply With Quote
50 amp
