Old 05-31-2016, 03:23 PM   #11
mrpep's Avatar
This is what I added to my tt antenna line and it's a bit better but wonder if an antenna upgrade or that winegard add on would improve. I placed this amp in my home and it did wonders just don't see wonders in tt, just a slight improvement.
mrpep is offline   Reply With Quote
Old 05-31-2016, 03:42 PM   #12
Canadian Member
itat's Avatar
Originally Posted by mrpep View Post
If I climb up on the roof and look at the antenna it should say make and model somewhere ?
Does it look like this one?
http://www.amazon.com/Winegard-RV-30...=1&*entries*=0
itat is online now   Reply With Quote
Old 05-31-2016, 03:43 PM   #13
mrpep's Avatar
Yes
Old 05-31-2016, 03:50 PM   #14
Ddubya's Avatar
Here are Winegard configurations
Standard
Name:   ImageUploadedByForest River Forums1464727734.389122.jpg
Wingman attachment
Name:   ImageUploadedByForest River Forums1464727767.306612.jpg
Complete antenna with attachment
Name:   ImageUploadedByForest River Forums1464727811.974858.jpg
Ddubya is offline   Reply With Quote
Old 05-31-2016, 03:51 PM   #15
Canadian Member
itat's Avatar
Here is a video from Winegard on how to upgrade the Sensar III with their Wingman add-on for better reception.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-31-2016, 04:00 PM   #16
Ddubya's Avatar
The amplifier that worked in your home did so because your antenna is UHF compliant
It does not work in the RV because the antenna is not picking up UHF so nothing to amplify
Add the Wingman attachment and you should have signal.
Old 05-31-2016, 04:01 PM   #17
mrpep's Avatar
I will order it and try it out , thanks
Old 05-31-2016, 04:05 PM   #18
Did you put this between the antenna and the antenna power supply plate or between the plate and tv?
An "HD" antenna does not exist. The only thing that matters (unless you get into satellites) is what frequency they are broadcasting on. Voice or data or video or Morse code doesn't matter.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 05-31-2016, 04:36 PM   #19
Ddubya's Avatar
As I stated earlier. Most stations are broadcasting on the UHF TV band. He has no UHF antenna so no or very little signal.
Most people do not know that the antennas did not change when the conversion to digital happened. Antenna manufacturers and retailers make the public believe they need a new antenna.
The carrier frequency's remained the same but most VHF stations switched to UHF due to the VHF band being taken from them by the FCC.
If you had a VHF/UHF combo antenna you were usually OK. I say usually because the new ATSC broadcasting standard can be very fickle. You may get a strong signal but your neighbors may not.
Old 05-31-2016, 04:47 PM   #20
mrpep's Avatar
It is in between the tv and antenna , hope that makes sense .
antenna, upgrade
