Old 05-31-2016, 05:04 PM   #21
B and B's Avatar
Originally Posted by mrpep View Post
This is what I added to my tt antenna line and it's a bit better but wonder if an antenna upgrade or that winegard add on would improve. I placed this amp in my home and it did wonders just don't see wonders in tt, just a slight improvement.
Hello,
This amplifier would raise the noise floor on the signals, might help but might also hinder. This amp is designed for CABLE TV and the signals are not as high in Frequency therefore I would remove it. The Winegaurd has a amplifier inside it already. Add a wingman antenna and should increase UHF reception.
UHF TV has been around since the 50's. Nothing new just new Digital channels are in the UHF band below old CH 50 mostly. They are lower power than old analogue TV.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-31-2016, 05:34 PM   #22
Ddubya's Avatar
Chances are that the amplifier is blocking the 12VDC required to operate the antenna thus rendering it useless
Ddubya is offline   Reply With Quote
Old 05-31-2016, 05:45 PM   #23
It is in between the tv and antenna , hope that makes sense .
The coax plate near your TV with the little button and green light sends 12 volts to your antenna to power it's built in amp. If you installed yours between the plate and antenna you are blocking that 12 volts. If you connected it between the antenna port on the front of that plate and the TV you're ok.
Also open panels and check connectors and trace coax. Mine was wired with the satellite port on the outside wired to the output of a 2way standard splitter. No go from the factory!
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 05-31-2016, 07:11 PM   #24
mrpep's Avatar
The amp has a electrical plug which gives it 12 volts as well
mrpep is offline   Reply With Quote
Old 05-31-2016, 07:48 PM   #25
Give 12 volts to the PCT amp. The antenna on the roof has its own built in amp that gets 12 volts over the coax from the coax plate I mentioned. If you put anything between that plate and the antenna there's no 12volts to the antenna. When your PCT amp says bi directional it means passing data both ways for cable modems and cable boxes. It does not pass the 12 volts the antenna needs.
Old 05-31-2016, 08:17 PM   #26
mrpep's Avatar
So remove my amps ?
Old 06-01-2016, 02:40 PM   #27
Upgrade to HD antenna
I had great success with the wingman add on, however it interfered when lowering it did not clear my roof mount AC. So I returned it to CW.
I then installed the much smaller compact design "Jack" brand HD antenna with great results.
My dilemma now is I have a different TT with plenty of room on the roof for either one.
What has been the results of the Jack vs the Wingman add on.
Any input appreciated. Is one better than the other? The Jack is more compact, just wonder if others have had favorable or unfavorable results with it. Thanks
Poper is offline   Reply With Quote
Old 06-01-2016, 03:45 PM   #28
Ddubya's Avatar
Should I upgrade to HD antenna?
Mrpep
If you are adding the wingman then you only use the amplifier that is in the wall plate. Anything else will only add to your problems.
Old 06-01-2016, 04:24 PM   #29
Poper, I've got both. The Jack seems to have a wider receive pattern but either seems to work same distance. Just a little easier to point in general direction with the Jack, scan then fine tune.
Old 06-01-2016, 04:33 PM   #30
mrpep's Avatar
Is the amp in the wall plate hidden ? I don't see one .
antenna, upgrade
